Date Picker
3059
09-08-2010 04:25 AM
KathleenBrenkert
I noticed yesterday that when I use a date field in my attribute inspector, it will display the date I enter minus 1 day.  So if I pick Sept 8, close my attribute inspector and reopen it-Sept 7 is displayed.  The date in my database is stored as Sept 8.
I noticed this sample is displaying the same behavior for me: http://help.arcgis.com/en/webapi/flex/samples/index.html
My system calendars/clocks as far as I know are correct.  Is this a bug in the 2.0 library or my system?
my set up for this field is pretty basic.  The following is contained within the AttributeInspector tags (ZInspect is a date field):
<esri:FieldInspector featureLayer="{myFeatureLayer}" fieldName="ZInspect"/>
DasaPaddock
This is a AGS 10.0 REST bug. Were you referring to this sample?
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=AttributeInspectorInfoWindowEditable
Here's a workaround:
            private function myFeatureLayer_selectionCompleteHandler(event:FeatureLayerEvent):void
                // only show infoWindow if a feature was found
                if (event.featureLayer.numGraphics > 0)
                    status.text = "Feature selected";
                    for each (var field:Field in event.featureLayer.layerDetails.fields)
                        if (field.type == Field.TYPE_DATE)
                            for each (var feature:Graphic in event.features)
                                var date:Date = new Date(feature.attributes[field.name]);
                                if (date.milliseconds == 999)
                                    date.milliseconds++; //Add 1ms to date values ending in 999 to workaround REST date bug
                                    feature.attributes[field.name] = date.time;
                    myMap.infoWindow.show(queryMapClick.geometry as MapPoint);
                else
                    if (!status.text == "Feature deleted.") //avoid showing the alert box, immediately after deleting
                        status.text = "";
                        Alert.show("Sorry found nothing here...");
KathleenBrenkert
That is the sample, and the fix worked like a charm!
thanks!
KathleenBrenkert
My date picker is also defaulting to 12/29/1899 when the field is null.  How do I set the date picker to start with a more resonable date, say today's?
DavidCaussin
Hi all,
Is it possible to change the date format MM/DD/YYYY in DD/MM/YYYY?
I already change the date format on the server where arcgis server is running but that change nothing
Thanks a lot.
David
