Date and Time Data Extract Output Name
13253
23
10-11-2016 08:43 PM
AhmadSopian1
I would like to ask how to change the name of the resulting data extract into the current date and time??? thanks master..
outputFileName = (configXML.outputfilename[0] || "yyyy-MMM-dd-HHmmss") + ".zip";
outputFileName = outputFileName.replace(/(\\|\/|:|\?|"|<|>|\|)/g, "");‍‍
DanPatterson_Retired
it doesn't seem to replace dashes ... is that the issue or is getting the date time which you haven't show how you are getting??   In any event, once you have your date converted to a string use 'replace' to substitute the string elements    replace("-","")  yields 'YYYYMMMdd'
AhmadSopian1
thanks you Patterson,,
i don't have date time string, can you help me for source data string date time for data extract arcgis flex?
sorry... I thought it would return that format of date, my comment was on the replace segment... it won't replace dashes if that is the format that is returned
RobertScheitlin__GISP
Ahmad,
   It would be something like this:
<mx:DateFormatter id="formatDate" formatString="YYYY-MMM-DD-LNNSS" />
outputFileName = (configXML.outputfilename[0] || formatDate.format(new Date)) + ".zip";
AhmadSopian1
Thanks Robert, you very helpful
AhmadSopian1
Hello Mr. Robert,
Can u Help me..
Can add names format, if you choose shp format, will generate a name behind shp,,
outputFileName = (configXML.outputfilename[0] || formatDate.format(new Date)) + "format choose"+ ".zip";
Ahmad,
outputFileName = (configXML.outputfilename[0] || formatDate.format(new Date)) + formatDDL.selectedItem.data.substring(0, formatDDL.selectedItem.data.indexOf("-") - 1) + ".zip";
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
AhmadSopian1
Sorry Mr. Robert,
i have not been able to find the solution of my problem to add the extension of the selected format.
Ahmad,
   When you tested what did it give you?
If you want just the file extension then try:
outputFileName = (configXML.outputfilename[0] || formatDate.format(new Date)) + formatDDL.selectedItem.data.substring(format.lastIndexOf(".") + 1, formatDDL.selectedItem.data.length) + ".zip";
