Date and Time Data Extract Output Name
13186
23
10-11-2016 08:43 PM
AhmadSopian1
I would like to ask how to change the name of the resulting data extract into the current date and time??? thanks master..
outputFileName = (configXML.outputfilename[0] || "yyyy-MMM-dd-HHmmss") + ".zip";
outputFileName = outputFileName.replace(/(\\|\/|:|\?|"|<|>|\|)/g, "");‍‍
AhmadSopian1
Mr. Robert
i've tried to source code, but the error.
outputFileName = (configXML.outputfilename[0] || formatDate.format(new Date)) + formatDDL.selectedItem.data.substring(format.lastIndexOf(".") + 1, formatDDL.selectedItem.data.length) + ".zip";
RobertScheitlin__GISP
Ahmad,
   So did you add:
<mx:DateFormatter id="formatDate" formatString="YYYY-MMM-DD-LNNSS" />
AhmadSopian1
Mr. Robert,
i've add,
but,
Ahmad,
  OK I see the issue. Try this:
outputFileName = (configXML.outputfilename[0] || formatDate.format(new Date)) + formatDDL.selectedItem.data.substring(formatDDL.selectedItem.data.lastIndexOf(".") + 1, formatDDL.selectedItem.data.length) + ".zip";
AhmadSopian1
Mr. Robert,
I problem, after compile, its widget error.
Ahmad,
   Did you put the mx:DateFormatter in the <fx:Declarations> section?
When you debug what does the error window say?
AhmadSopian1
Mr. Robert,
Yes, i put mx:DateFormatter in the <fx:Declarations>...
but i do not get error messages when compiling.
<?xml version="1.0" encoding="utf-8"?>
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:s="library://ns.adobe.com/flex/spark"
                   xmlns:mx="library://ns.adobe.com/flex/mx"
                   xmlns:viewer="com.esri.viewer.*"
                   xmlns:esri="http://www.esri.com/2008/ags"
                   widgetConfigLoaded="init()">
    <fx:Script>
        <![CDATA[
            import com.esri.ags.FeatureSet;
            import com.esri.ags.Graphic;
            import com.esri.ags.events.DrawEvent;
            import com.esri.ags.events.GeometryServiceEvent;
            import com.esri.ags.events.GeoprocessorEvent;
            import com.esri.ags.geometry.Extent;
            import com.esri.ags.geometry.Geometry;
            import com.esri.ags.geometry.MapPoint;
            import com.esri.ags.geometry.Polygon;
            import com.esri.ags.layers.GraphicsLayer;
            import com.esri.ags.symbols.Symbol;
            import com.esri.ags.tasks.GeometryServiceSingleton;
            import com.esri.ags.tasks.supportClasses.GPMessage;
            import com.esri.ags.tasks.supportClasses.JobInfo;
            import com.esri.ags.tools.DrawTool;
            import com.esri.ags.tools.NavigationTool;
            import com.esri.ags.utils.GeometryUtil;
            import com.esri.ags.utils.GraphicUtil;
            import com.esri.viewer.AppEvent;
            import com.esri.viewer.ViewerContainer;
            import com.esri.viewer.utils.ErrorMessageUtil;
            import com.esri.viewer.utils.GenericJSONTask;
            import mx.collections.ArrayCollection;
            import mx.controls.Alert;
            import mx.events.CloseEvent;
            import mx.rpc.AsyncResponder;
            import mx.rpc.Fault;
            import mx.rpc.events.FaultEvent;
            private var dataUrl:String = "";
            private var file:FileReference;
            private var outputFileName:String;
            private var finishDrawing:Boolean;
            private var graphicsLayer:GraphicsLayer;
            private var graphicContextMenu:ContextMenu;
            private var gpService:GenericJSONTask;
            private var selectedDrawingIcon:Image;
            private var drawSymbol:Symbol;
            [Bindable]
            private var exposeLayers:Boolean = true; //later set to FALSE!!
            private var formatChoiceList:ArrayCollection;
            private var rasterFormatChoiceList:ArrayCollection;
            [Bindable]
            private var rasterFormatChoiceListVisible:Boolean;
            private var spatialReferenceChoiceList:ArrayCollection;
            [Bindable]
            private var spatialReferenceChoiceListVisible:Boolean;
            [Bindable]
            private var gpURL:String;
            [Bindable]
            private var layers:ArrayCollection;
            private var excludeLayers:Array = [];
            [Bindable]
            private var useCurrentExtentAsAIO:Boolean = false;
            private var useProxy:Boolean;
            //labels
            [Bindable]
            private var descLabel:String;
            [Bindable]
            private var step1Label:String;
            [Bindable]
            private var polygonLabel:String;
            [Bindable]
            private var freehandPolygonLabel:String;
            [Bindable]
            private var rectangleLabel:String;
            [Bindable]
            private var circleLabel:String;
            [Bindable]
            private var ellipseLabel:String;
            [Bindable]
            private var clearLabel:String;
            [Bindable]
            private var dataCurrentExtentLabel:String;
            [Bindable]
            private var step2Label:String;
            [Bindable]
            private var step3Label:String;
            [Bindable]
            private var step4Label:String;
            [Bindable]
            private var step5Label:String;
            [Bindable]
            private var extractButtonLabel:String;
            private var step1ErrorLabel:String;
            private var step2ErrorLabel:String;
            private var emptyResultsLabel:String;
            private var saveDataFileLabel:String;
            private function init():void
                graphicsLayer = new GraphicsLayer();
                map.addLayer(graphicsLayer);
                if (configXML)
                    if (GeometryServiceSingleton.instance.url) // using GeometryServiceSingleton
                        geometryService.url = GeometryServiceSingleton.instance.url;
                        geometryService.token = GeometryServiceSingleton.instance.token;
                        geometryService.proxyURL = GeometryServiceSingleton.instance.proxyURL;
                    // TODO: check for non-existance
                    gpURL = String(configXML.dataextractionservice);
                    if (String(configXML.aioselectionmethod) == "extent")
                        useCurrentExtentAsAIO = true;
                    else
                        useCurrentExtentAsAIO = false;
                    //useproxy
                    if (configXML.useproxy.length() > 0)
                        useProxy = configXML.useproxy == "true";
                    gpService = new GenericJSONTask();
                    gpService.url = gpURL;
                    if (useProxy && configData.proxyUrl)
                        gpService.proxyURL = configData.proxyUrl;
                        gp.proxyURL = configData.proxyUrl;
                    var urlVars:URLVariables = new URLVariables();
                    urlVars.f = "json";
                    //Call gpService to get service properties
                    gpService.execute(urlVars, new AsyncResponder(gpService_resultHandler, gpService_faultHandler));
                    // exclude these layers
                    var excludeLayersXML:XMLList = configXML.excludelayer as XMLList;
                    for (var i:int = 0; i < excludeLayersXML.length(); i++)
                        excludeLayers.push(excludeLayersXML.toString());
                    outputFileName = outputFileName.replace(/(\\|\/|:|\?|"|<|>|\|)/g, ""); //strip illegal characters
                    graphicsLayer.name = configXML.layername || widgetTitle;
                    //labels
                    descLabel = configXML.labels.desclabel[0] || getDefaultString("descLabel");
                    step1Label = configXML.labels.step1label[0] || getDefaultString("step1Label");
                    polygonLabel = configXML.labels.polygonlabel[0] || getDefaultString("drawPolygonLabel");
                    freehandPolygonLabel = configXML.labels.freehandpolygonlabel[0] || getDefaultString("drawFreehandPolygonLabel");
                    rectangleLabel = configXML.labels.rectanglelabel[0] || getDefaultString("drawRectangleLabel");
                    circleLabel = configXML.labels.circlelabel[0] || getDefaultString("drawCircleLabel");
                    ellipseLabel = configXML.labels.ellipselabel[0] || getDefaultString("drawEllipseLabel");
                    clearLabel = configXML.labels.clearlabel[0] || getDefaultString("clearLabel");
                    dataCurrentExtentLabel = configXML.labels.datacurrentextentlabel[0] || getDefaultString("dataCurrentExtentLabel");
                    step2Label = configXML.labels.step2label[0] || getDefaultString("step2Label");
                    step3Label = configXML.labels.step3label[0] || getDefaultString("step3Label");
                    step4Label = configXML.labels.step4label[0] || getDefaultString("step4Label");
                    step5Label = configXML.labels.step5label[0] || getDefaultString("step5Label");
                    extractButtonLabel = configXML.labels.extractbuttonlabel[0] || getDefaultString("extractButtonLabel");
                    step1ErrorLabel = configXML.labels.step1errorlabel[0] || getDefaultString("step1ErrorLabel");
                    step2ErrorLabel = configXML.labels.step2errorlabel[0] || getDefaultString("step2ErrorLabel");
                    emptyResultsLabel = configXML.labels.emptyresultslabel[0] || getDefaultString("emptyResultsLabel");
                    saveDataFileLabel = configXML.labels.savedatafilelabel[0] || getDefaultString("saveDataFileLabel");
                    initGraphicContextMenu();
                AppEvent.addListener(AppEvent.DATA_PUBLISH, viewerContainer_dataPublishHandler);
            private function initGraphicContextMenu():void
                graphicContextMenu = new ContextMenu();
                graphicContextMenu.hideBuiltInItems();
                var menuItem:ContextMenuItem = new ContextMenuItem(clearLabel);
                menuItem.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, menuItem_contextMenuDeleteHandler);
                graphicContextMenu.customItems.push(menuItem);
            protected function menuItem_contextMenuDeleteHandler(event:ContextMenuEvent):void
                var graphic:Graphic = event.contextMenuOwner as Graphic;
                var graphicsLayer:GraphicsLayer = graphic.graphicsLayer;
                graphicsLayer.remove(graphic);
            private function makeHTMLSafe(content:String):String
                content = content.replace(/>/g, "&gt;");
                content = content.replace(/</g, "&lt;");
                return content;
            private function callGPService():void
                var geometries:Array = getInputGeometries();
                if (geometries)
                    if (needToSimplifyPolygons(geometries))
                        geometryService.simplify(geometries);
                    else
                        createGPParamsAndExtract(geometries);
                else
                    showError(step1ErrorLabel);
            private function getInputGeometries():Array
                var geometries:Array;
                if (useCurrentExtentAsAIO)
                    geometries = [ getMapExtentEnvelope()];
                else if (graphicsLayer.numGraphics > 0)
                    var graphics:Array = (graphicsLayer.graphicProvider as ArrayCollection).toArray();
                    geometries = GraphicUtil.getGeometries(graphics);
                return geometries;
            private function createGPParamsAndExtract(geometries:Array):void
                var clipFS:FeatureSet = createClipFeatureSet(geometries);
                if (clipFS)
                    var params:Object;
                    params = createGPParams(clipFS);
                    if (params)
                        setMapNavigation(null, null);
                        swfMessage.visible = true;
                        gp.processSpatialReference = map.spatialReference;
                        gp.outSpatialReference = map.spatialReference;
                        gp.submitJob(params);
            private function needToSimplifyPolygons(geometries:Array):Boolean
                var hasSelfIntersectingPolygons:Boolean = false;
                for each (var geometry:Geometry in geometries)
                    if (geometry.type == Geometry.POLYGON)
                        if (GeometryUtil.polygonSelfIntersecting(geometry as Polygon))
                            hasSelfIntersectingPolygons = true;
                            break;
                return hasSelfIntersectingPolygons;
            private function createGPParams(clipFS:FeatureSet):Object
                var gpParams:Object;
                if (exposeLayers)
                    var layersToClip:Array = [];
                    for (var i:int = 0; i < layers.length; i++)
                        if (layers.getItemAt(i).selected)
                            layersToClip.push(layers.getItemAt(i).label);
                    if (layersToClip.length > 0)
                        gpParams =
                                "Area_of_Interest": clipFS,
                                "Feature_Format": formatDDL.selectedItem.data,
                                "Layers_to_Clip": layersToClip
                        // add if necessary
                        if (rasterFormatDDL.visible)
                            gpParams["Raster_Format"] = rasterFormatDDL.selectedItem.data;
                        if (spatialReferenceDDL.visible)
                            gpParams["Spatial_Reference"] = spatialReferenceDDL.selectedItem.data;
                    else
                        showError(step2ErrorLabel);
                else
                    gpParams =
                    // add if necessary
                    if (rasterFormatChoiceListVisible)
                    if (spatialReferenceChoiceListVisible)
                return gpParams;
            private function createClipFeatureSet(geometries:Array):FeatureSet
                var clipFS:FeatureSet;
                var features:Array = [];
                    features.push({ geometry: geometry });
                clipFS = new FeatureSet();
                clipFS.spatialReference = map.spatialReference;
                clipFS.features = features;
                return clipFS;
            private function getMapExtentEnvelope():Polygon
                //create the extent as a polygon
                var mapExtentEnvelope:Polygon = new Polygon(null, map.spatialReference);
                mapExtentEnvelope.rings =
                     new MapPoint(map.extent.xmin, map.extent.ymin),
                     new MapPoint(map.extent.xmax, map.extent.ymin),
                     new MapPoint(map.extent.xmax, map.extent.ymax),
                     new MapPoint(map.extent.xmin, map.extent.ymax),
                return mapExtentEnvelope;
            // Draw functions
            private function activateDrawTool(event:MouseEvent):void
                addSharedData("Deactivate_DrawTool", null); // to be able to deactivate drawTool on other widgets
                // apply glow
                selectedDrawingIcon = Image(event.currentTarget);
                clearSelectionFilter();
                selectedDrawingIcon.filters = [ glowFilter ];
                finishDrawing = false;
                dataUrl = "";
                var status:String;
                var value:String = selectedDrawingIcon.name;
                switch (value)
                    case DrawTool.POLYGON:
                        status = polygonLabel;
                        break;
                    case DrawTool.FREEHAND_POLYGON:
                        status = freehandPolygonLabel;
                        break;
                    case DrawTool.EXTENT:
                        status = rectangleLabel;
                        break;
                    case DrawTool.CIRCLE:
                        status = circleLabel;
                        break;
                    case DrawTool.ELLIPSE:
                        status = ellipseLabel;
                        break;
                drawSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, 0x3FAFDC, 0.5, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, 0x3FAFDC, 1, 2));
                setMapAction(value, status, drawSymbol, map_drawEndHandler);
            private function clearSelectionFilter():void
                for (var i:int = 0; i < aioBox.numChildren; i++)
                    if (aioBox.getChildAt(i).filters && aioBox.getChildAt(i).filters.length > 0)
                        if (!(selectedDrawingIcon && aioBox.getChildAt(i) === selectedDrawingIcon))
                            aioBox.getChildAt(i).filters = [];
            private function onTurnOnNav():void
                setMapNavigation(NavigationTool.PAN, "Pan Map");
            private function clear():void
                onTurnOnNav();
                graphicsLayer.clear();
            private function viewerContainer_dataPublishHandler(event:AppEvent):void
                var data:Object = event.data;
                if (data.key == "Deactivate_DrawTool")
                    setMapAction(null, null, null, null);
                    if (selectedDrawingIcon)
                        selectedDrawingIcon.filters = [];
                        selectedDrawingIcon = null;
            private function wTemplate_closedHandler(event:Event):void
                graphicsLayer.visible = false;
                setMapAction(null, null, null, null); // deactivate drawTool
            private function wTemplate_openHandler(event:Event):void
                if (graphicsLayer)
                    graphicsLayer.visible = true;
            private function wTemplate_minimizedHandler(event:Event):void
            private function icon_rollOverHandler(event:MouseEvent):void
                event.target.filters = [ glowFilter ];
            private function icon_rollOutHandler(event:MouseEvent):void
            private function map_drawEndHandler(event:DrawEvent):void
                // deactivate the draw tool
                finishDrawing = true;
                onTurnOnNav();
                var graphic:Graphic = event.graphic;
                graphic.contextMenu = graphicContextMenu;
                if (graphic.geometry is Extent)
                    // convert extent to a polygon
                    const extent:Extent = Extent(graphic.geometry);
                    var extentPolygon:Polygon = new Polygon(null, map.spatialReference);
                    extentPolygon.rings = [[
                                           new MapPoint(extent.xmin, extent.ymin),
                                           new MapPoint(extent.xmax, extent.ymin),
                                           new MapPoint(extent.xmax, extent.ymax),
                                           new MapPoint(extent.xmin, extent.ymax),
                    graphic.geometry = extentPolygon;
                graphic.symbol = drawSymbol;
                // add graphic to the graphics layer
                graphicsLayer.add(graphic);
            private function gp_jobCompleteHandler(event:GeoprocessorEvent):void
                swfMessage.visible = false;
                if (event.jobInfo.jobStatus == JobInfo.STATUS_SUCCEEDED)
                    gp.getResultData(gp.submitJobLastResult.jobId,
                                     "Output_Zip_File"); // parameterName
                else
                    var msg:String = getDefaultString("problemLabel") + "\n\n\n" + event.jobInfo.jobStatus;
                    if (event.jobInfo.messages)
                        msg += "\n\n\n" + GPMessage(event.jobInfo.messages[event.jobInfo.messages.length - 1]).description;
                    showError(msg);
            private function gp_getResultDataCompleteHandler(event:GeoprocessorEvent):void
                if (event.parameterValue)
                    dataUrl = String(event.parameterValue.value.url);
                    if (!dataUrl)
                        showError(emptyResultsLabel);
                        return;
                    Alert.show(saveDataFileLabel, wTemplate.widgetTitle, Alert.YES | Alert.NO, null, alert_ClickHandler);
                else
            // Event handler function for displaying the selected Alert button.
            private function alert_ClickHandler(event:CloseEvent):void
                if (event.detail == Alert.YES)
                    downloadFile(dataUrl);
            private function downloadFile(url:String):void
                var downloadURL:URLRequest = new URLRequest();
                downloadURL.url = url;
                file = new FileReference();
                // TODO: can we be smarter with the name of the zip file? For example, for single layers, using a modified layer name?
                file.download(downloadURL, outputFileName);
            private function gp_faultHandler(event:FaultEvent):void
                var msg:String = getDefaultString("problemLabel") + "\n\n\n" + event.fault.faultString;
                showError(msg);
            private function gpService_resultHandler(serviceProperties:Object, token:Object = null):void
                var params:Array = serviceProperties.parameters;
                rasterFormatChoiceListVisible = false;
                spatialReferenceChoiceListVisible = false;
                for (var i:int = 0; i < params.length; i++)
                    if (params.name == "Layers_to_Clip")
                        layers = new ArrayCollection();
                        exposeLayers = true;
                        for each (var layer:Object in params.choiceList)
                            if (excludeLayers.indexOf(layer) == -1)
                                var obj:Object = { label: layer, selected: false };
                                layers.addItem(obj);
                    if (params.name == "Feature_Format")
                        formatChoiceList = new ArrayCollection();
                        for each (var format:String in params.choiceList)
                            const fileLabel:String = format.substring(0, format.indexOf("-") - 1);
                            const fileExtension:String = format.substring(format.lastIndexOf("."), format.length);
                            formatChoiceList.addItem({ data: format, label: fileLabel + " (" + fileExtension + ")" });
                    if (params.name == "Raster_Format")
                        rasterFormatChoiceListVisible = true;
                        rasterFormatChoiceList = new ArrayCollection();
                        for each (var rasterFormat:String in params.choiceList)
                            const fileLabel1:String = rasterFormat.substring(0, rasterFormat.indexOf("-") - 1);
                            const fileExtension1:String = rasterFormat.substring(rasterFormat.lastIndexOf("."), rasterFormat.length);
                            rasterFormatChoiceList.addItem({ data: rasterFormat, label: fileLabel1 + " (" + fileExtension1 + ")" });
                    if (params.name == "Spatial_Reference")
                        spatialReferenceChoiceListVisible = true;
                        spatialReferenceChoiceList = new ArrayCollection();
                        for each (var spatialReferenceString:String in params.choiceList)
                            spatialReferenceChoiceList.addItem({ data: spatialReferenceString, label: spatialReferenceString });
                checkBoxDG.dataProvider = layers;
                formatDDL.dataProvider = formatChoiceList;
                rasterFormatDDL.dataProvider = rasterFormatChoiceList;
                spatialReferenceDDL.dataProvider = spatialReferenceChoiceList;
            private function gpService_faultHandler(fault:Fault, token:Object = null):void
                var msg:String = "Unable to connect to GP Service:\n"
                    + gp.url + "\n\n"
                    + "Most likely cause:\n"
                    + ErrorMessageUtil.getKnownErrorCauseMessage(fault.faultCode) + "\n\n"
                    + "Details:\n"
                    + makeHTMLSafe(fault.toString());
                showError(msg);
                widgetVBox.enabled = false;
            private function geometryService_faultHandler(event:FaultEvent):void
                showError(event.fault.toString());
            private function geometryService_simplifyHandler(event:GeometryServiceEvent):void
                createGPParamsAndExtract(event.result as Array);
    </fx:Script>
    <fx:Declarations>
        <esri:SimpleFillSymbol id="sfs"
                               alpha="0.8"
                               color="#FFFFFF">
            <esri:SimpleLineSymbol width="2"
                                   color="#00FF00"
                                   style="solid"/>
        </esri:SimpleFillSymbol>
        <mx:DateFormatter id="formatDate" formatString="YYYY-MMM-DD-HHNNSS"/>
        <esri:GeometryService id="geometryService"
                              fault="geometryService_faultHandler(event)"
                              simplifyComplete="geometryService_simplifyHandler(event)"
                              url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/>
        <!-- GP -->
        <esri:Geoprocessor id="gp"
                           concurrency="last"
                           fault="gp_faultHandler(event)"
                           getResultDataComplete="gp_getResultDataCompleteHandler(event)"
                           jobComplete="gp_jobCompleteHandler(event)"
                           url="{gpURL}"/>
        <!-- Effects and Filters-->
        <s:GlowFilter id="glowFilter"
                      alpha="1"
                      color="{getStyle('focusColor')}"
                      inner="true"
                      strength="2"/>
    </fx:Declarations>
    <viewer:WidgetTemplate id="wTemplate"
                           width="320" height="300"
                           closed="wTemplate_closedHandler(event)"
                           minHeight="300"
                           minWidth="320"
                           minimized="wTemplate_minimizedHandler(event)"
                           open="wTemplate_openHandler(event)">
        <s:Scroller width="100%" height="100%"
                    horizontalScrollPolicy="off">
            <s:VGroup id="widgetVBox"
                      gap="4"
                      verticalAlign="middle">
                <s:Label width="100%" text="{descLabel}"/>
                <mx:Spacer/>
                <s:HGroup id="aioBox"
                          width="100%" height="40"
                          gap="0"
                          horizontalAlign="left"
                          includeInLayout="{!useCurrentExtentAsAIO}"
                          visible="{!useCurrentExtentAsAIO}">
                    <s:VGroup height="100%">
                        <s:Label text="{step1Label}"/>
                        <mx:Spacer height="100%"/>
                        <s:HGroup width="100%" height="100%"
                                  horizontalAlign="right"
                                  paddingBottom="3">
                            <s:Label click="clear()"
                                     text="{clearLabel}"
                                     textDecoration="underline"
                                              buttonMode="true"
                                              useHandCursor="true"/>
                        </s:HGroup>
                    </s:VGroup>
                    <mx:Image name="{DrawTool.EXTENT}"
                              width="40" height="40"
                              buttonMode="true"
                              click="activateDrawTool(event)"
                              rollOut="icon_rollOutHandler(event)"
                              rollOver="icon_rollOverHandler(event)"
                              source="assets/images/i_draw_rect.png"
                              toolTip="{rectangleLabel}"
                    <mx:Image name="{DrawTool.CIRCLE}"
                              buttonMode="true"
                              source="assets/images/i_draw_circle.png"
                              toolTip="{circleLabel}"
                    <mx:Image name="{DrawTool.ELLIPSE}"
                              buttonMode="true"
                              source="assets/images/i_draw_ellipse.png"
                              toolTip="{ellipseLabel}"
                    <mx:Image name="{DrawTool.POLYGON}"
                              buttonMode="true"
                              source="assets/images/i_draw_poly.png"
                              toolTip="{polygonLabel}"
                    <mx:Image name="{DrawTool.FREEHAND_POLYGON}"
                              buttonMode="true"
                              source="assets/images/i_draw_freepoly.png"
                              toolTip="{freehandPolygonLabel}"
                </s:HGroup>
                         includeInLayout="{useCurrentExtentAsAIO}"
                         text="{dataCurrentExtentLabel}"
                         visible="{useCurrentExtentAsAIO}"/>
                <s:Line width="100%">
                    <s:stroke>
                        <s:SolidColorStroke color="0xEEEEEE" weight="2"/>
                    </s:stroke>
                </s:Line>
                <s:VGroup width="{wTemplate.width - 40}" height="{widgetVBox.height - aioBox.height - 110}"
                          gap="4"
                          includeInLayout="{exposeLayers}"
                          visible="{exposeLayers}">
                    <s:Label paddingTop="4" text="{step2Label}"/>
                    <s:Scroller width="100%" height="100%">
                        <s:DataGroup id="checkBoxDG" dataProvider="{layers}">
                            <s:layout>
                                <s:VerticalLayout gap="2"
                                                  useVirtualLayout="true"/>
                            </s:layout>
                            <s:itemRenderer>
                                <fx:Component>
                                    <s:DataRenderer>
                                                  <s:CheckBox label="{data.label}" selected="@{data.selected}">
                                                  </s:CheckBox>
                                    </s:DataRenderer>
                                </fx:Component>
                            </s:itemRenderer>
                        </s:DataGroup>
                    </s:Scroller>
                </s:VGroup>
                    <s:stroke>
                    </s:stroke>
                </s:Line>
                <s:VGroup width="100%" height="100%">
                    <s:Label paddingTop="4" text="{step3Label}"/>
                    <s:DropDownList id="formatDDL"
                                    width="100%"
                                    requireSelection="true"/>
                    <s:Label includeInLayout="{rasterFormatChoiceListVisible}"
                             paddingTop="4"
                             text="{step4Label}"
                             visible="{rasterFormatChoiceListVisible}"/>
                    <s:DropDownList id="rasterFormatDDL"
                                    width="100%"
                    <s:Label includeInLayout="{spatialReferenceChoiceListVisible}"
                             paddingTop="4"
                             text="{step5Label}"
                             visible="{spatialReferenceChoiceListVisible}"/>
                    <s:DropDownList id="spatialReferenceDDL"
                                    width="100%"
                    <s:HGroup width="100%" verticalAlign="middle">
                        <s:Button id="extract"
                                  click="callGPService()"
                                  horizontalCenter="0"
                                  label="{extractButtonLabel}"/>
                        <mx:Image id="swfMessage"
                                  source="assets/images/loader.swf"
                                  visible="false"/>
                    </s:HGroup>
                </s:VGroup>
            </s:VGroup>
        </s:Scroller>
    </viewer:WidgetTemplate>
</viewer:BaseWidget>
when I use mozilla display an error message
DanPatterson_Retired
line 663 you have the date format wrong.... you have HHNNSS for time... shouldn't that be HHMMSS
M not N
AhmadSopian1
Thanks Mr. Patterson has responded,
but I also have problems to add the file extension in the name of the downloaded.
that was just one error I found skimming the document... I suggest you go through it slowly and check to see if there are any other errors or go back to the stage where it worked then sequentially add more 'bits' until it fails.  It appears that you did a whole load of things all at once and the error is buried in the sequence of your activities.  Incrementally build and test before you move forward is prudent
And on that note what is outFilename supposed to look like?  Why don't you hard code it for now  ie  c:\temp\test.zip to see if everything works up to that point.  If it doesn't, the error lies in the concatenation of the filename or one of the elements therein.  Does this java(?) stuff not have the ability to print?  I will let you read through it to see if the parts of the concatenation are correct and provide a sample of what the output filename is supposed to look like... perhaps you shouldn't use a ".zip" extension but "zip" without the period... maybe you have 2 periods in the output.
