dataprovider in mxml for esri graphic layer?
1457
6
11-01-2012 06:46 AM
TomRauch
Hi, as you know datagrids and other sorts of controls in Flasbuilder can be populated using an MXML 'dataprovider' reference bound to some data object.
I am wondering if there is a way to provide a dataprovider 'equivalent' for an esri graphics layer?  Or do graphics layers need to be populated through Action Script code, not through MXML?
Thanks, Tom
KenBuja
MVP Esteemed Contributor
The graphic layer does have the graphicProvider property. Here's an example.
DasaPaddock
Also see this sample that shows declaring Graphics in MXML:
http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Adding_Graphics/01nq00000012000000/
Since the graphicProvider is the default MXML property for the GraphicsLayer, it's not explicitly set in the MXML above.
http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/layers/GraphicsLayer.html
TomRauch
Terrific!  Thanks for the responses.  I will try these out over the week-end!
Tom
TomRauch
So here's what I am trying to do: use the 'graphicProvider' datasource in MXML to access a data service object that spits out a bunch of these XML elements:
<post>
<id>2</id>
<src>nc</src>
<eqid>71786976</eqid>
<version>0</version>
<day>Thursday</day>
<date>2012-05-17</date>
<time>04:38:38</time>
<lat>38.810000</lat>
<lon>-122.829500</lon>
<magnitude>0.6</magnitude>
<depth_km>3.0</depth_km>
<depth_mi>1.9</depth_mi>
<pr_km>2</pr_km>
<pr_mi>1</pr_mi>
<NST>10</NST>
<region>Northern California</region>
</post>
I'd like to access that data service object through the graphicProvider, specifically the lat/lon from the XML to provide location information for the markers (x={lat}, y={lon}).
is that possible?  When I associate my data object reference to graphicProvider, I get an error - trying to coerce a valueObject that is not supported by GraphicLayer.
Thanks for any help/guidance.
Tom
KenBuja
Have you seen this sample that puts the results of a GeoRSS feed on a graphics layer?
TomRauch
Ken, thanks, I have not seen that sample but it looks promising.  I will investigate further.  I am trying to create maps with location markers mostly through MXML and staying as light as I can on the AS3 coding.
