DataGrid MouseOver
2527
07-28-2014 11:35 AM
GlenReid
I have a DataGrid that displays some information.  I'm trying to use a mouseOver event to get some information from the grid:
<s:DataGrid id="indexGrid" width="335" height="162" top="4" dataProvider="{indexList}"
  mouseOver="indexGrid_mouseOverHandler(event)" mouseOut="indexGrid_mouseOutHandler(event)">
  <s:columns>
    <s:ArrayList>
      <s:GridColumn headerText="Region" width="175" dataField="REGION"/>
      <s:GridColumn headerText="Category" width="75" dataField="CATEGORY"/>
      <s:GridColumn headerText="Index" width="80" labelFunction="formatIndex" dataField="RSI"/>
    </s:ArrayList>
  </s:columns>
</s:DataGrid>
In my event handler, I can get the value of a column, but only with a hardcoded row:
private function indexGrid_mouseOverHandler(event:MouseEvent):void {
  trace (event.currentTarget.dataProvider.getItemAt(0).REGION);
  trace (event.currentTarget.dataProvider.getItemAt(0).RSI);
  trace (event.currentTarget.dataProvider.getItemAt(1).REGION);
  trace (event.currentTarget.dataProvider.getItemAt(1).RSI);
Anyone know how to get the index of the datagrid row?
RobertScheitlin__GISP
Glen,
  Sorry about that. Use gridRollOver and GridRollOut events and event.itemRenderer.data
and you need to check if the itemRenderer exists
if(!event.itemRenderer || !event.itemRenderer.data){
     return;
Glen,
Listen to the itemRollOver event instead of mouseOver and the event has a rowIndex property
private function onItemRollOver(event:ListEvent):void
    var rowIndex:int = event.rowIndex;
GlenReid
Robert,
The datagrid doesn't have the itemRollOver event, but list does....is that what you are referring to?
Glen
Glen,
     return;
