Data Binding from LayerTOC
4243
11
11-10-2010 03:20 PM
JasonLevine
Hello All,
    I'm working with the flex sample code (non sample viewer) found in the resource center, specifically with the "Identify" and "Dynamic Map Layers on/off" components.  In my identify function, I've added an identify parameter "identifyParams.layerIds = [0]" to only run the identify on the specified layer in my map service (in the example below, the specified layer is the layer with a layer ID of 0):
var identifyParams:IdentifyParameters = new IdentifyParameters();
    identifyParams.returnGeometry = true;
    identifyParams.tolerance = 3;
    identifyParams.width = myMap.width;
    identifyParams.height = myMap.height;
    identifyParams.geometry = event.mapPoint;
    identifyParams.mapExtent = myMap.extent;
    identifyParams.spatialReference = myMap.spatialReference;
    identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
    identifyParams.layerIds = [0];
In the LayerTOC.mxml, I'd like to create an itemClick function in the DataGrid that does the following:
1) Create a new array variable
2) populates the array with the Layer ID of the selected layer in the TOC
I'd like to then bind the new array variable to my main.mxml and set it as the array for my identifyParams.layerIds array.  Basically, I want to be able to set the layer I'd like to do the identify on by selecting it in the TOC. The concept seems pretty straightforward, but I can't seem to create and bind my array without creating several errors.
Any help is appreciated.
Jason
by Anonymous User
Not applicable
Hi Jason,
This would be user friendly.  Have you tried using a switch and case functionality to store the layerId information in a class / object?
For example create and then import a simple class / object like below and use a switch / case statement to populate the object.
public class IdentifyHelper
   private var _myIds:Array;
   public function get myIds():Array
      return this.myIds;
   public function set myIds( value:Array ):void
      this.myIds = value;
   /* in theory all your identify parameters could go here, if you desire a different look and feel for each layer */
Next in code, set the object property in a switch / case based on the layer you want "active"
switch (myString) {
    case "Rivers":
        identifyhelper.myIds = [0];
        break;
    case "Lakes":
        identifyhelper.myIds = [1];
        break;
    case "Plants":
        identifyhelper.myIds = [2];
        break;
Then when it comes time to do the Identify you could "get" your layerId parameters out of the object, as follows.
identifyParams.layerIds = identifyhelper.myIds;
You could also create a simple object at the global scope and not go with a full blown class with getters and setters.  Down the road, though, I think the above logic would make for a strong framework.  It's a little more extensible and could be recycled in other projects.
Regards,
Doug Carroll, ESRI Support Services SDK Team
http://support.esri.com/
JasonLevine
Hi Doug,
   Thanks for this idea, I think it'll work nicely. However, I'm running into some errors while compiling.
I've created and imported my IdentifyHelper.as class:
package com.esri.ags.script
   return this.myIds;
   this.myIds = value;
Then, in my LayerTOC.mxml, I've created an itemClick function in the DataGrid:
private function onItemClick(event):void
    switch (this.selectedItem.name)
     case "Zoning":
      IdentifyHelper.myIds = [4];
      break;
     case "LUP - Area Comm Plan":
      IdentifyHelper.myIds = [5];
      break;
     case "LUP - General Plan":
      IdentifyHelper.myIds = [6];
      break;
And in my Main.mxml, I've included the IdentifyHelper.myIds:
protected function mapClickHandler(event:MapMouseEvent):void
    clickGraphicsLayer.clear();
    graphiclayer.clear();
    identifyParams.width = map.width;
    identifyParams.height = map.height;
    identifyParams.mapExtent = map.extent;
    identifyParams.spatialReference = map.spatialReference;
    identifyParams.layerIds = IdentifyHelper.myIds;
    var clickGraphic:Graphic = new Graphic(event.mapPoint, clickPtSym);
    clickGraphicsLayer.add(clickGraphic);
    identifyTask.execute(identifyParams, new AsyncResponder(myResultFunction, myFaultFunction, clickGraphic));
The problem I'm having is that everywhere in my code where I reference "IdentifyHelper.myIds"
I get the following error:
1119:Access of possibly undefined property myIds through a reference with static type Class.
Is this an issue of casting?
Jason
JasonLevine
Anyone know how to resolve this error?
DasaPaddock
It looks like you need to create and use an instance of IdentifyHelper.
JasonLevine
Hello Dasa,
   So I've created an instance of IdentifyHelper here:
public static var identify:IdentifyHelper = new IdentifyHelper;
     case "Zoning":
      identify.myIds = [4];
      break;
      identify.myIds = [5];
      break;
      identify.myIds = [6];
      break;
And referenced it here:
    identifyParams.layerIds = com.esri.ags.samples.LayerTOC.identify.myIds;
This resolved the errors, but now my identify tool wont work at all.  Any ideas?
Jason
DasaPaddock
The code looks OK. Try running the debugger and checking that the values are what you expect. You can also try a tool like HttpFox to see what's being sent to the server.
JasonLevine
Hi Dasa,
   I've been scouring over my code and everything looks OK to me as well; The only think I can think of is that the array isn't being populated with any values at all and this is what is causing the identify tool to not work.  How can I check to see what is being loaded into the myIds array when I click on a layer in the TOC?  Is there a way to just trace out the array somewhere so I can at least verify that the values are being loded and are changing as I click layers in the TOC?
Jason
JasonLevine
Ok, I debugged, and I receive the following ArgumentError as soon as I click the map:
ArgumentError: Error #2025: The supplied DisplayObject must be a child of the caller.
 at flash.display::DisplayObjectContainer/getChildIndex()
 at mx.managers::SystemManager/getChildIndex()
 at mx.managers.systemClasses::ActiveWindowManager/mouseDownHandler()
How would I go about fixing this?
Jason
JasonLevine
Ok, I've discovered that the ArgumentError was a result of nesting Applications within my main Application;  changing the main <S:Application> to <S:Group> in all of my components fixed this.
Back to the main issue.... When debugging, Flash Builder throws an error when I try to select a layer from my TOC list:
undefined
 at com.esri.ags.script::IdentifyHelper/set myIds()
This corresponds to the line 12 (myIds = value ) of my IdentifyHelper.as file:
   return myIds;
  public function set myIds(value:Array):void
   myIds = value;
Is there something wrong with my IdentifyHelper.as code at that line?
Thanks for your help,
Jason
