Custom tab function
1465
01-29-2011 05:52 AM
WesBailes
I understand that this should be on a general flex forum but i haven't found a good one yet.
I have a need for a custom tab function for use between textinput controls. The only way that it works is if I call Alert.show("something"); after the command. At the top of the application, I have the tabChildren set to false.* event listener declaration code:*
textInput1.setFocus();
textInput2.addEventListener(KeyboardEvent.KEY_DOWN ,kH);
* handler code is:*
private function kH(event:KeyboardEvent):void {
if (event.keyCode == Keyboard.TAB) {*
textinput2.setFocus();
//only works with the following line uncommented*****
//Alert.show("made it"); } }* Any suggestions are appreciated!
RobertScheitlin__GISP
Wes,
   Here is a sample of this working:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      minWidth="955" minHeight="600" tabChildren="false"
      creationComplete="init()">
 <s:layout>
  <s:VerticalLayout gap="4"/>
 </s:layout>
 <fx:Script>
  <![CDATA[
   private function init():void
    //This code is needed to give the flex application itself the focus
                                //The getElementById('Wes') Wes is the name of the application.
    navigateToURL(new URLRequest("javascript: document.getElementById('Wes').focus();"), "_self");
    //Now give the focus to the first input
    textInput1.addEventListener(KeyboardEvent.KEY_DOWN ,kH);
     textInput2.setFocus();
 </fx:Script>
 <s:TextInput id="textInput1" text="hello" />
 <s:TextInput id="textInput2" text="good bye" />
</s:Application>
WesBailes
Thanks Robert!  Works great.
