custom layout in AttributeInspector  fot the FieldInspectors
1037
04-27-2010 08:03 AM
TomSchuller
Hy,
we want to use a more complex layout for representing the FieldInspectors in the AttibuteInspector.
By default, the features attributes  is represented in a simple grid (colCount=2):
  for each feature field: a gridrow with a label and an renderer
We want to place the FieldInspector (label+renderer) in a more complex grid, like a grid with 4 columns or even more comples.
We ddn't found a way to do it directly with the AttributeInspector or with the AttributeInspectorSkin who has just exposed the container form.
How can we create our custom FieldInspector-layout in the AttributeInspector.
To add additional components (buttons) inside the AttributeInspector woudl also be helpful.
Has anybody a solution or are these planned features for the final versions?
Tom
JesúsVillalobos
I have the same problem. Have you found a solution?
Thanks!
EddieJesinsky
Currently trying to figure out if this is possible as well! I suspect not
JesúsVillalobos
I found a solution. Not the best solution but it works.
I write down the source code. This code puts fields in 2 tabs, and in the first one, fields are shown in 2 columns.
Bye 🙂
<s:HGroup id="contenedorDelFormulario">
  <mx:TabNavigator>
   <s:NavigatorContent label="{configFormularios.pestanaTitle}" width="600" height="400">
    <s:HGroup verticalAlign="middle" width="100%" height="100%">
     <esri:AttributeInspector left="6" right="6" top="6" bottom="6" width="100%"
            featureLayers="{hostComponent.featureLayers}"
            formItemsOrder="fieldInspector" deleteButtonVisible="false">
      <esri:FieldInspector featureLayer="{hostComponent.featureLayers[1]}"
            fieldName="NOM"
            label="Nombre"/>
            fieldName="CODI_CARRETERA"
            label="Códigooo"/>
            fieldName="ID_CARRETERA"
            visible="false"/>
            fieldName="DATA_CONS"
            visible="false"/>
            fieldName="DATA_VIGENCIA_FIN"
            visible="false"/>
            fieldName="DATA_VIGENCIA_INICIO"
            visible="false"/>
            fieldName="LONGITUD"
            visible="false"/>
     </esri:AttributeInspector>
            fieldName="NOM"
            label="Nombre" visible="false"/>
            label="Códigooo" visible="false"/>
            visible="true"/>
            visible="false"/>
            visible="false"/>
            visible="false"/>
            visible="true"/>
    </s:HGroup>
   </s:NavigatorContent>
   <s:NavigatorContent label="Fechas" width="300" height="200">
            fieldName="NOM"
            visible="false"/>
            visible="true"/>
            visible="true"/>
            visible="true"/>
            visible="false"/>
    </s:HGroup>
  </mx:TabNavigator>
 </s:HGroup>
