Custom JSONDecoder for ID Task Result
1285
02-07-2012 07:21 AM
BrianBehling
The problem:
When the ESRI API decodes a response from the identify task, there is a few second lock in the Flash application which is due to the decoding of the results.
I have used chunk parsing algorithms in action script to prevent the UI from locking, and I would like to implement this for the ID task response decoding.
I assume the class I need to extend is the com.esri.serlization.jason.JSONDecoder class. Does anyone know how I can get that code so I can re-write it, and use this extended class to parse the results from the ID task? Or, if I use a third party JSON decoder and re-write it, how can I use this class to parse the results from the ID task?
DasaPaddock
Customizing the JSONDecoder class is not supported. You could use HTTPService to make the REST request directly and then decode the result using a different decoder.
http://help.arcgis.com/en/arcgisserver/10.0/apis/rest/identify.html
Another option is trying ArcGIS API 3.0 Beta 1 since it uses the Flash Player's native JSON class when running in FP 11+ and this is very fast:
http://resourcesbeta.esri.com/en/webapis/flex-api/community/
http://resourcesbeta.esri.com/en/webapis/flex-api/apiref/com/esri/ags/utils/JSONUtil.html
BrianBehling
Thanks for the reply. I'll give this a try.
BrianBehling
I found this pretty cool JSON asynchronous decoder below.
http://blog.brokenfunction.com/2010/10/actionjson-the-fastest-actionscript-3-0-json-parser/
Using the JsonDecoderAsync and green threading techniques adopted from JavaScript, I can parse through an identify result with about 3000 without any UI locks.
