Create an infowindow in a flex mobile project
9498
22
05-09-2013 12:55 PM
buslimmohcine
Hi i need to creat an infowindow in a flex mobile project from my feature of point can i have  help 😛
buslimmohcine
Tks alote now i need to costumise the infowindow size its possible 🙂
AaronNash1
here is a project that was posted on github called mobilemapboilerplate. It was shown during the developer summit, it is a highly developed mobile app in Flex. Has comprehensive skinnging and a dynamic UI for tablets and phones. They built a really good skin for callouts with better drop down menus for editing. I would use this as a base.
buslimmohcine
tks for ur replay this is  a very important code for mobile developpement but i have same trouble to run the project
i use flash builder 4.6
sdk 4
KomanDiabate
Hi Yann,
I talked to you yesterday about the mobile-map-boilerplate app at the ESRI conference and I really like what you have shown me. However, I am having problem to run the application on my computer, not exactly sure what is going on. I was wondering if you can help? I am getting a launch failed error (See image below). I am using FB 4.6 and SDK 4.6.
Thanks in advance.
[ATTACH=CONFIG]25905[/ATTACH]
AaronNash1
change the adobe air version in your descriptor file from 3.5 to 3.4, attached is a screen shot
KomanDiabate
Hi Aaron, that didn't work. Here what I am getting now..
[ATTACH=CONFIG]25929[/ATTACH]
KomanDiabate
Ok, the issue is solved. After a little bit of googling....
It looks like the descriptor file requires the 3.1 version.
see link: http://forums.adobe.com/message/4731948
Thanks Aaron for pointing me in the right direction.
AaronNash1
sorry, i am on the 4.9.1 SDK. With 4.6 use 3.1 instead of 3.4,
