Could not resolve <s:controlBarContent> to a component implementation ...Urgent Help
4535
8
06-01-2011 07:58 AM
by Anonymous User
Not applicable
Original User: sravabonagiri
Hi Flex Gurus,
I need a small favor. I am working on a dropdown control and zoom to feature (point) for a beach application. I was able to implement the attached code alright for a standalone application. But, When I am adding the code as a custom widget to my existing code....I am getting the following error. That is, Could not resolve <s:controlBarContent> to a component implementation. I attached the code as well as error image here. Could you please help me fix the issue. Please let me know if you need further information. Many thanks for your help.
Sam
by Anonymous User
Not applicable
Original User: rscheitlin
Sam,
Here is what you have so far fixed:
<?xml version="1.0" encoding="utf-8"?>
// Copyright (c) 2010 ESRI
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions.  See use restrictions in the file:
// <install location>/License.txt
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
       xmlns:s="library://ns.adobe.com/flex/spark"
       xmlns:mx="library://ns.adobe.com/flex/mx"
       xmlns:esri="http://www.esri.com/2008/ags"
       xmlns:custom="components.*"
       xmlns:viewer="com.esri.viewer.*"
       widgetConfigLoaded="init()">
 <fx:Declarations>
  <esri:QueryTask id="queryTask"
      executeComplete="queryTask_executeCompleteHandler(event)"
      showBusyCursor="true"
      url="http://167.193.56.180/ArcGIS/rest/services/Georgia_Beach/MapServer/0"
      useAMF="false"/>
 </fx:Declarations>
 <fx:Script>
  <![CDATA[
   import com.esri.ags.Graphic;
   import com.esri.ags.events.MapEvent;
   import com.esri.ags.events.QueryEvent;
   import com.esri.ags.geometry.Extent;
   import com.esri.ags.geometry.Geometry;
   import com.esri.ags.geometry.MapPoint;
   import com.esri.ags.tasks.supportClasses.Query;
   import com.esri.ags.utils.GraphicUtil;
   import mx.collections.ArrayCollection;
   import mx.collections.ArrayList;
   import spark.events.IndexChangeEvent;
   protected function init():void
    var query:Query = new Query();
    query.outFields = [ "NAME_1" ];
    query.outSpatialReference = map.spatialReference;
    query.returnGeometry = true;
    query.where = "1=1";
    queryTask.execute(query);
   protected function queryTask_executeCompleteHandler(event:QueryEvent):void
    ddList.dataProvider = new ArrayList(event.featureSet.features);
   protected function ddListLabelFunction(item:Graphic):String
    return item.attributes["NAME_1"];
   protected function ddList_changeHandler(event:IndexChangeEvent):void
    var pt:MapPoint = MapPoint(Graphic(ddList.selectedItem).geometry);
    var beachExtent:Extent = new Extent(pt.x - 100, pt.y -100, pt.x + 100, pt.y + 100);
    map.extent = beachExtent
    // make sure the whole extent is visible
    if (!map.extent.contains(beachExtent))
     map.level--;
 </fx:Script>
 <viewer:WidgetTemplate id="DropDown" width="300" height="200" >
  <viewer:layout>
   <s:HorizontalLayout horizontalAlign="center" verticalAlign="middle"/>
  </viewer:layout>
   <s:DropDownList id="ddList"
       width="200"
       change="ddList_changeHandler(event)"
       labelFunction="ddListLabelFunction"
       prompt="Choose a beach..."/>
 </viewer:WidgetTemplate>
</viewer:BaseWidget>
ShravanBonagiri
Hi Robert,
Thanks for your help. I appreciate it. I was able to get past that error. But, I have another issue facing me. That is, call to a undefined method query. I attached the error file. The error is showing up in init() function for method Query. Your help is appreciated.
by Anonymous User
Not applicable
Sam,
   What ESRI Flex API version are you using?
ShravanBonagiri
Robert,
I am using agslib-2.3.1-2011-04-26.
by Anonymous User
Not applicable
Sam,
   The issue I am having is that because the code already has:
There is no reason for that error if you are using agslib-2.3.1-2011-04-26...:confused:
ShravanBonagiri
Ok. Thanks for your continued support. I am new to Flex development. Previously, I was working with Silverlight API. I hear some compatibility issues with Flash Builder 4.5. Should I go back to Flash Builder 4.0?
Sam
by Anonymous User
Not applicable
Sam,
   No that is not the issue because I build the exact code I sent you using Flash Builder 4.5 and the 4.5 SDK as well.  See what happens when you fully qualify the query in the init function.
    var query:com.esri.ags.tasks.supportClasses.Query = new com.esri.ags.tasks.supportClasses.Query();
ShravanBonagiri
Excellent. It did the trick. Thanks for persisting with me. Thanks a ton.
