Coordinate Widget
2448
09-29-2010 11:40 AM
JefferyFuller
Total Newbie Question:
How do I add the Coordinate Widget to Config.xml?
It doesn't go in the Widget area does it?
Thanks for the help,
Trichoptera
RobertScheitlin__GISP
Trichoptera,
   If you look at the config-all.xml file in your FlexViewer it will show you an example usage.
MehulChoksey
Here is the configuration file that has coordinate widget:
http://help.arcgis.com/en/webapps/flexviewer/live/config-all.xml
You can see it in action at:(see below the scalebar)
http://help.arcgis.com/en/webapps/flexviewer/live/index.html?config=config-all.xml
JefferyFuller
Thanks!
That answers my question perfectly!
