Coordinate Widget Dual Output
1252
02-16-2011 05:48 AM
ScottSnider
Is there a way to have the Coordinate Widget display two data formats on the output?  I would like to be able to display dms and geo by default.
Scott
ReneRubalcava
Esri Frequent Contributor
This might help you out.
I just saw that someone put this up the other day
http://www.arcgis.com/home/item.html?id=bdd12eac11e14b5ebe11d011b0207120
BjornSvensson
Esri Alum
No, not out of the box.  Unless you use two coordinate widgets (same swf, but two different xml files)...
GeorgeHaskett
So I'm trying to use multiple coordinate widgets as suggested so that I can display different coordinate systems.
Is there a way to remove the Longitude: and Latitude: labels that come by default with the geo outputunit setting?
Also, can I reverse the order of the Lat/long x/y display?  I would like to set it up so that its consistantly x or long first, then y or lat second seperated with a comma.
I am using the Viewer for Flex 3.2.  I should be upgrading in the next few weeks to the 3.3.
Haskett
