Coded Domain in PopUp widget
1782
7
10-24-2011 06:25 AM
RickWeisbond
How do I display the text description, rather than the integer code, in the popup window for a layer in a mapservice referenced by the viewer?  I'm using the compiled flexviewer and only work with the config xml's and widget xml's.
SolomonNimako
I think in your domains you are using integers in the Code Values. If so let the code values be the text you will want your users see. Re-publish the map service, hope this helps
FabianoScardua
The compiled version don't display coded domain. You need make changes on your code to it make this.
RickWeisbond
That's what I was afraid of.  So, there's no way to do what I need to do by just altering the config files?  I need to get to the source code?
FabianoScardua
Yes, you need to change the source code.
FrankRoberts
Does anyone have the source code change they can provide?
MGSethe
I hope this was solved long time ago, i am stucked with the same problem , how was this problem solved?
FrankRoberts
I haven't seen code to solve it yet.  Any one??
