Clustering Sample doesn't display InfoWindow for non-clustered points
1409
06-17-2011 07:52 AM
KarlWilson
Does anyone know how I could modify the Clustering Sample so that when you zoom into individual points and click on them they display an InfoWindow.
Currently in the example above, an InfoWindow only appears when you click on one of the green points that are part of a cluster. When you click on an individual red point you don't get the InfoWindow.
Karl
AlexJones
Not tested, but you should just be able to add a click event to the feature layer or another event listener on the map. Try it out.
map.addEventListener(MouseEvent.CLICK,mouseClickHandler);
private function mouseClickHandler(event:MouseEvent):void
    showInfoWindow(Graphic(event.target),event.stageX, event.stageY);
or
 <esri:FeatureLayer id="featureLayer"
         clusterer="{clusterer}"
         definitionExpression="POP1990 &gt; 75000"
         mode="snapshot"
         outFields="*"
         symbol="{defaultsym}" click="mouseClickHandler(event)"
AlexJones
This sample shows a better way to handle the events. It uses a Graphic event and should help you avoid any type coercion errors.
protected function fLayer_graphicAddHandler(event:GraphicEvent):void
    event.graphic.addEventListener(MouseEvent.CLICK,mouseClickHandler);
         clusterer="{clusterer}" graphicAdd="fLayer_graphicAddHandler(event)"
         mode="snapshot"
         outFields="*"
the mouseClickHandler would be the same as above.
KarlWilson
That's great Alex, thanks.
Both methods work for me.
Karl
