Clustering Polygons
4057
05-19-2010 06:29 AM
YannickBourone
is there a possibility to cluster Polygons like in this sample?
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=FeatureLayerClustering
or does it only works with mappoints?
thanks
yannick
SteeveCouture
Did you get an answer to yours question?  I'm looking for a solution to display some polygons with lots of points with a better display performance.
Steeve
SteveMcKinney
Have you guys looked at the ThematicQuery example in the Fleviewer v2.1 widget located in Samples?
http://help.arcgis.com/en/webapps/flexviewer/samples/index.html#thematicquery.htm
It isn't truly a polygon cluster, but it does show how to give the appearance of disaggregation of polygons based on scale.
Steve McKinney
SICS Consultants, LLC
