Closest Facility Error 400- invalid URL
2382
06-16-2010 08:43 PM
MohammedAlSharif
Hi All,
I try to use the network closest facilities to solve the route from incident to the closest facility put it gave me this error Closest Facility Error 400- invalid URL. Can you help me in that and i will appreciated
Thanks and Regards,
Mohammed 🙂
DmitryKudinov
Hi Mohammed,
Please take a look at this Closest Facility sample here: http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=ClosestFacility
Please also note the Closest Facility REST endpoint this sample makes use of:
http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Closest%20Facility
if you are planning to point at your own CF service, you can open REST services directory
at http://<your_server>/ArcGIS/rest (for .NET Server) and http://<your_server>:8399/arcgis/rest/ (for Java Server) and browse to the Closest Facility layer you are going to use. Just copy this URL into your ClosestFacilityTask instance.
Dmitry
