Cloning Graphics and other ESRI Objects
3318
10-08-2010 06:51 AM
PeterMcAlenney
HI,
Often times i need to copy an Array of Graphics and it is not that easy.  For some reason the ESRI objects fail when you use the ObjectUtil.copy() function.  Below is a bit more code, consisting of 3 functions which is clone your Graphic objects (and anything else) when you needs to get deep clones or copies.
Let me know if you have any questions!
Pete
                 // These following 3 functions are used to deep
   // clone objects.
   public static function deepClone(source:Object):Object {
    var clone:Object;
    if(source) {
        clone = newSibling(source);
        if(clone) {
            copyData(source, clone);
    return clone;
      private static function newSibling(sourceObj:Object):* {
          if(sourceObj) {
              var objSibling:*;
              try {
                  var classOfSourceObj:Class = getDefinitionByName(getQualifiedClassName(sourceObj)) as Class;
                  objSibling = new classOfSourceObj();
              catch(e:Object) {}
              return objSibling;
          return null;
      private static function copyData(source:Object, destination:Object):void {
          //copies data from commonly named properties and getter/setter pairs
          if((source) && (destination)) {
              try {
                  var sourceInfo:XML = describeType(source);
                  var prop:XML;
                  for each(prop in sourceInfo.variable) {
                      if(destination.hasOwnProperty(prop.@name)) {
                          destination[prop.@name] = source[prop.@name];
                  for each(prop in sourceInfo.accessor) {
                      if(prop.@access == "readwrite") {
              catch (err:Object) {
FrankRoberts
Can you explain how I would use this to clone a com.esri.ags.Map?  I can put a map into it using:
var mymap:Object = deepClone(map);
But then I'm unclear how to convert the output "mymap" back into a map instead of an object.
Thanks for your help,
Frank
PeterMcAlenney
var mymap:Map = deepClone(map) as Map;
That should do it...
JohnGarvey
Thanks for the utils code.
Whenever I clone the map and add the clone to the display list (in this case within a flexviewer widget), both the original map and the clone are whited-out.
Sorry I don't have only a better description, but any help in diagnosing or solving is much appreciated.
Thanks
