Clear Everything!!
852
10-25-2010 06:05 PM
philippschnetzer
Hi All,
I am wondering about the feasibility of creating a single 'Recycle Bin' button that could be placed in the header area and it would clear absolutely all graphics or selected items with a single click on its icon in the header bar.
Thanks!
Drew
Hi All,
Thanks!
This is quite easy.. Here are the steps and code needed (replace this.map with your map component)
- Loop thought all the map layers and find the all the graphics layers (code below)
[php]
   * Get all the graphics layers inside the map
  public function GetAllGraphicLayers():ArrayCollection
   var graphicsLayers:ArrayCollection = new ArrayCollection();
   for each(var layer:Layer in this.map.layers)
       if (layer is GraphicsLayer)
        graphicsLayers.addItem(layer);
      return graphicsLayers;
[/php]
Then loop through all the graphic layers and clear..
[php]
public function ClearAll():void
   var graphicLayers:ArrayCollection = GetAllGraphicLayers();
   for each(var grapicsLayer:GraphicsLayer in graphicLayers)
    grapicsLayer.clear();
[/php]
You could combine all the code i guess but i have it broken out for other reasons.
Drew
