Classic Shortcut bar for 2.2?
2173
6
03-15-2011 08:42 AM
KentOgletree
I am trying to create a shortcut bar like the 1.3 SFV. However I have not found any sample available and all attempts to modify the Header Widget has resulted in it breaking. Every tiime I attempt to move the Widget List below the Title and Sub-Title all widgets grey out and can not be clicked.
Any suggestions on available sample code or where I might be going wrong in editing the existing code would be appreciated.
RobertScheitlin__GISP
kogletree,
   I still use the classic controller from the Flex Viewer Beta and have it running in Flex Viewer 2.2. Attached is the widget source.
Main Config.xml entry:
<widget left="20" top="10" visible="true"
        config="widgets/ClassicController/ClassicController.xml"
        url="widgets/ClassicController/ClassicControllerWidget.swf"/>
KentOgletree
Thanks Robert, however it appears that the Banner.mxml requires a resource file ControllerStrings for locale "en_US" which I do not have. If I could find the 1.3 source somewhere I would pull it out myself. Would you happen to have this resource?
Sure here it is. Just change dot txt to dot properties once you get it.
KentOgletree
Thanks again Robert. This is working great and I only have some styling stuff to do and then make a few mods. This has saved me some grief. 😄
JesseMetcalfe
Hello Guys,
Thanks for sharing Classic banner for 2.2.
However, after adding the code and doing possible modifications it is not working for me.
  • Added widget to src/widgets
  • Added Banner.mxml and ClassicControllerWidget to flex modules
  • Removed HeaderController from config.xml
  • Added ClassicControllerWidget entry to config.xml
My banner seem to be blank.(Attaching image)
Is there any thing I am missing ?
Jesse
JesseMetcalfe
forgot to attach my banner
