Change ESRI flex sample from checkboxes into radiobuttons
2593
8
04-29-2010 07:37 AM
FranciscoDomingues
Hi all,
Trying to change the ESRI flex sample from checkboxes into radiobuttons I reach the point where I select the radiobutton layers and the layers activate correctly, but when I select another layer the previous checked one do not de-select.
Any tips where and what to change in the code?
Thanks!
PrashanthSukumaran
It is treating the radio buttons as separate/individual radio buttons.  You need to assign a group name to the radio button.
By doing so you will have only one radiobutton selected at a time.
http://livedocs.adobe.com/flex/3/langref/mx/controls/RadioButtonGroup.html#includeExamplesSummary
SebastianRoberts
Did you get this to work?  I am trying to change the check boxes to radio buttons on one of my live maps widgets (sample LiveMapsWidgets).  Can you provide the code if you were able to do this?
SebastianRoberts
I was able to updatet the live maps widget to use radio buttons instead of checkboxes, and have one slider on the same pane as the radio buttons. This slider controls the currently chosen layer (images in my case). The one minor problem that I still have, is that I cannot format the radio button label text. It shows up transparent and faint. I tried setting the stlye to widget text radioBtn.setStyle ("textFormat","WidgetText"). I also tried creating my own TextFormat and applying that to the radio buttons. Anyone have any ideas? Below is my LiveMapsWidget.mxml.
(Note: if you try to use this code, I also added a setter function called layerToNone to the LayerAlpha.mxml that just sets the slider text to "none").
Sebastian Roberts
Nevada County, CA GIS
<?xml version="1.0" encoding="utf-8"?>
// Copyright © 2008 - 2009 ESRI
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions.  See use restrictions in the file:
// <install location>/FlexViewer/License.txt
<BaseWidget xmlns    ="com.esri.solutions.flexviewer.*"
   xmlns:mx   ="http://www.adobe.com/2006/mxml"
   xmlns:toccomp  ="com.esri.solutions.flexviewer.components.toc.*"
   xmlns:widgets  ="com.esri.solutions.flexviewer.widgets.*"
   x     ="600"
   y     ="300"
   widgetConfigLoaded ="init()">
 <mx:Script>
  <![CDATA[
   import com.esri.ags.Map;
   import com.esri.ags.layers.GraphicsLayer;
   import com.esri.ags.layers.Layer;
   import com.esri.solutions.flexviewer.AppEvent;
   import com.esri.solutions.flexviewer.ConfigData;
   import com.esri.solutions.flexviewer.SiteContainer;
   import com.esri.solutions.flexviewer.components.toc.tocClasses.TocItem;
   import com.esri.solutions.flexviewer.utils.WidgetEffects;
   import mx.collections.*;
   import mx.controls.Alert;
   import mx.controls.RadioButton;
   import mx.events.ItemClickEvent;
   import mx.events.ListEvent;
   import mx.events.StateChangeEvent;
   //labels
   [Bindable]
   private var visibilityLabel:String;
   [Bindable]
   private var transparencyLabel:String;
   private var lArr:Array;
   private const ICON_URL:String = "com/esri/solutions/flexviewer/assets/images/icons/";
   private function init():void
    if (configXML)
     //labels
     visibilityLabel = configXML.labels.visibilitylabel || "Layer Visibility";
     transparencyLabel = configXML.labels.transparencylabel || "Layer Transparency";
    lArr = getLayers();
    aLayerSlider.layerToNone = "Select an image, then this slider will adjust transparency";
    wTemplate.addTitlebarButton(ICON_URL + "i_folder.png", "Radio Buttons", showStateToggleLayers);
    var rBFormat:TextFormat = new TextFormat;
    rBFormat.font = "Arial";
    rBFormat.size = "11";
    rBFormat.color = "#FFFFFF";
    rBFormat.bold = true;
    for(var i:uint = 0; i < lArr.length; i++)
     var radioBtn:RadioButton = new RadioButton;
     radioBtn.groupName = "radioBtnGroup";
     radioBtn.label = lArr.name;
     radioBtn.setStyle("textFormat","rBFormat");
     radioBtn.value = i;
     radioBtn.alpha = 1
     radioBtn.height = 14
     vBoxRadio.addChild(radioBtn);
    //add a button for "none", ie no layer to be displayed
    radioBtn.value = lArr.length;
    radioBtn.label = "None";
    //set the current selection to the "none" button
    radioBtnGroup.selectedValue = lArr.length;
   private function getLayers():Array
    var basemapCount:Number = configData.configBasemaps.length;
    var layerArray:Array = [];
    for (var i:Number = map.layerIds.length -1; i >= basemapCount; i--)
     var layer:Layer = map.getLayer(map.layerIds);
     //change this to exclude any layers from the live map widgets.
     if (!(layer is GraphicsLayer) && (layer.name!= "Supervisor Districts") && (layer.name!= "Schools & Fire Stations"))
      layerArray.push(layer);
    return layerArray;
   private function showStateToggleLayers(event:MouseEvent):void
    WidgetEffects.flipWidget(this, viewStack, "selectedIndex", 0, 400);
   private function radioClickHandler(event:ItemClickEvent):void
    //if no layer is selected, then set the slider text appropriately.
    if (event.index == lArr.length){
    // update the visible layers to only show the layer selected
     if (lArr.name == event.label){
      map.getLayer(lArr.name).visible = true;
      var lay:Layer = map.getLayer(lArr.name);
      aLayerSlider.layer = lay;
     }else{
      map.getLayer(lArr.name).visible = false;
 </mx:Script>
 <WidgetTemplate id="wTemplate">
  <mx:ViewStack id="viewStack" width="100%" height="200%" creationPolicy="all">
   <mx:VBox id="vBoxRadio" width="100%" height="200%" horizontalScrollPolicy="off" verticalScrollPolicy="off">
    <mx:Label text="Choose an Image" styleName="WidgetText" width="100%"/>
     <mx:RadioButtonGroup id="radioBtnGroup" itemClick="radioClickHandler(event)"/>
     <widgets:LayerAlpha id="aLayerSlider"/>
   </mx:VBox>
  </mx:ViewStack>
 </WidgetTemplate>
</BaseWidget>
SandeepTalasila
Have any one tried to implement this in flex viewer 2.1? If so could you help me. I was trying to figure out but no luck yet.
SandeepTalasila
I was trying to implement radio buttons in the layer list instead of check boxes in Flex Viewer 2.1. I have made some changes in my LayerListWidget.mxml. I am not getting any results(see image). Probably my code is a blunder. could anyone please let me know how to make this work. Thanks for the help.
     // Copyright (c) 2010 ESRI
     // <install location>/License.txt
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:s="library://ns.adobe.com/flex/spark"
                   xmlns:mx="library://ns.adobe.com/flex/mx"
                   xmlns:viewer="com.esri.viewer.*"
                   xmlns:toc="com.esri.viewer.components.toc.*"
                   x="600" y="400"
                   widgetConfigLoaded="init()">
    <fx:Script>
        <![CDATA[
   import mx.collections.ArrayCollection;
   import spark.components.RadioButton;
            [Bindable]
            private var title:String;
     private var layers:ArrayCollection;
             toc.map = map;
                toc.isMapServiceOnly = false; //gotta get this from the config file
                toc.excludeLayers = getExcludeLayers();
                toc.excludeGraphicsLayers = true;
                if (configXML)
                    title = configXML.labels.title || "Map Layer List";
    rBFormat.color = "#000000";
    for (var i:uint = 0; i < layers.length; i++)
     radioBtn.label = layers.name;
     radioBtn.value = i;
     radioBtn.alpha = 1
    radioBtn.value = layers.length;
    radioBtnGroup.selected = layers.length;
            private function getExcludeLayers():ArrayCollection
                var result:ArrayCollection = new ArrayCollection();
                if (configData && configData.basemaps)
                    // exclude basemaps
                    for (var i:int = 0; i < configData.basemaps.length; i++)
                        result.addItem(configData.basemaps.label);
                if (configXML)
                    // exclude these layers
                    var layers:XMLList = configXML.excludelayer as XMLList;
                    for (var j:Number = 0; j < layers.length(); j++)
                        result.addItem(layers.toString());
                return result;
  viewStack.selectedIndex = 0;
  for(var i:uint = 0; i < layers.length; i++)
   if (layers.name == event.label){
    map.getLayer(layers.name).visible = true;
    var lay:Layer = map.getLayer(layers.name);
   }else{
    map.getLayer(layers.name).visible = false;
    </fx:Script>
    <viewer:WidgetTemplate id="wTemplate" width="300" height="300">
  <viewer:layout>
            <s:VerticalLayout gap="8" paddingTop="15"/>
        </viewer:layout>
        <s:Label text="{title}"/>
  <toc:TOC id="toc" width="100%" height="100%"/>
  <s:RadioButton id="radioBtnGroup" />
  <mx:ViewStack id="viewStack" width="100%" height="100%" creationPolicy="all" paddingTop="4" />
    </viewer:WidgetTemplate>
</viewer:BaseWidget>
SarahBell
Hey! I was able to change the appearance of the buttons to be radio buttons. At the end of this solution, I also have a big question/need for help.
How to make radio buttons in the TOC:
First I switched out any of the checkbox icons, skins, imports, and extensions in the "CheckBoxScaleDependantIcon.as" and the "CheckBoxScaleDependant.as" to RadioButton elements. This turned all the buttons into radio buttons.
So in "CheckBoxScaleDependantIcon.as" I deleted
import mx.skins.halo.CheckBoxIcon;
and replaced it with
import mx.skins.halo.RadioButtonIcon;
And in "CheckBoxScaleDependant.as" I replaced the Checkbox imported items with:
It's important that you remove any imports of checkbox items.
Last Change: change the following in "CheckBoxScaleDependant.as":
setStyle("icon", CheckBoxIcon);
to
setStyle("icon", RadioButtonIcon);
The radio buttons needed two clicks to appear "on", even though their data was rendered on the map. To fix this, I located the if (data is Tocitem() statement in the "TocItemRenderer.as" file. Here I deleted the
_checkbox.selected = item.visible; property. Great! Now the radio buttons themselves are acting like radio buttons. But I have a huge problem.
The map layers that each radio button turns on will stay on even when I click another radio button. If you have any suggestions to fix this, please reply! Thanks!
SebastianRoberts
Sarah,
  I haven't used the TOC, so I am not sure how it manages the layers, but in my widget that uses radio buttons, I just put the layers in an array, and then in the radio click handler I turn all layers off that don't correspond to the click event.
Putting all the operational layers that exist in the main config.xml file into an array:
   private function getLayers():void
    if (configData && configData.opLayers){
     for (var i:int=0; i< configData.opLayers.length; i++)
     layerArray.addItem(configData.opLayers.label);
excluding any layers listed as exclude in the widget's config file
private function excludeLayers(): void
    if (configXML){
     var layers:XMLList = configXML..excludelayer as XMLList;
     for (var j:Number = 0; j < layers.length(); j++){
      for(var i:int=0; i< layerArray.length; i++){
       if(layerArray == layers){
        layerArray.removeItemAt(i);
create radio buttons:
for(var i:uint = 0; i < layerArray.length; i++)
     radioBtn = new RadioButton;
     radioBtn.label = layerArray;
     radioBtn.styleName = "WidgetText";
     radioBtn.value = i;
     radioBtn.height = 18
     radioBtn.setStyle("textRollOverColor","#D0D0D0 ")
radio click handler:
     if (layerArray == event.label){
      map.getLayer(layerArray).visible = true;
     }else{
      map.getLayer(layerArray).visible = false;
SarahBell
Thanks for the reply, Sebastian. I will give it a try!
Sarah
