Change default right-click context menu on <esri:Map/>
3128
04-28-2010 09:44 AM
ErikEndrulat
I'm developing an Adobe Air map application. Due to security requirements, it's crucial that the application does not provide the ability to open a browser window via any menus, etc.
I just noticed that when you right-click on the map object, the context menu includes 'About ArcGIS for Flex', which opens up another window that has a link to the ESRI API site.
Is there any way to over ride this behavior?
Thanks
ErikEndrulat
I think I just resolved my own question, perhaps not the most elegant solution, but it works:
to the <esri:Map> </> code block, I added:
[INDENT]rightMouseDown="{Alert.show('right click disabled')}"[/INDENT]
Thanks
PrashanthSukumaran
You can also do this. Just in case you want to add custom menu items to the map. disabling right click will not work.
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
  creationComplete="onCreationComplete()"
  xmlns:mx=http://www.adobe.com/2006/mxml
  xmlns:esri=http://www.esri.com/2008/ags>
   <mx:Script>
   <![CDATA[
[INDENT]
[LEFT]   privatefunction onCreationComplete() : void
     var contextMenu:ContextMenu = new ContextMenu();
     contextMenu.hideBuiltInItems();
     myMap.contextMenu = contextMenu;
     contextMenu.customItems.push(new ContextMenuItem("Custom Menu Item",true));
[/LEFT]
[/INDENT]   ]]>
   </mx:Script>
 <esri:Map id="myMap" width="100%">
     <esri:ArcGISTiledMapServiceLayer
url="
http://server.arcgisonline.com/ArcGIS/rest/services/USA_Topo_Maps/MapServer" />
 </esri:Map>
</mx:Application>
