change attachment color in PopUp
1250
07-08-2013 08:42 AM
RinatSolorzano_Palero
Good morning,
I'm having some problems with the PopUp widget because the attachments appear inside a Rectangle with white color fill as in the following image
[ATTACH=CONFIG]25795[/ATTACH]
And I can't figure the attachment name till I click on it, which is a problem. I know that the Renderer for this inspector is in AttachmentRenderer.mxml but it's already compiled in the API used, so i can't change it directly. So i would appreciate your help to change this color or just erase that fill
Thanks a lot
Rinat S.
RobertScheitlin__GISP
Rinat,
   The easiest way is to do a monkey patch by adding the exact package path to your project in flex
com\esri\ags\skins\supportClasses\ and then paste the AttachmentRenderer.mxml from the API source in that new package (also known as a directory) and make your changes to it and they should show up when you build your project.
Rinat,
Rinat,
Thanks a lot Robert
It works fine!
Rinat S.
