Case sensitive query task
3947
01-27-2011 07:48 AM
MikeJun
I have query task to seach first name however users have to type first letter as upper case just like value in the attribute table. For example, they have to type like 'John' not 'john'. Is there way that users can type either upper or lower case?
<esri:Query id="queryFname" text="%{qTextFname.text}%" where="FName like '%{qTextFname.text}%'">
ReneRubalcava
Esri Frequent Contributor
If it's just the one name you're worried about you could do this
var qName:String = qTextFname.text.toLowerCase();
var len:int = qName.length;
var ucase:String = qName.charAt(0).toUpperCase();
var temp:String = qName.substr(1, len);
var newName:String = ucase + temp;
AS3 doesn't have a simple capitalize function.
OOh, found a regex method to do it for multiple words
http://stackoverflow.com/questions/860394/flex-capitalize-words-in-string
RobertScheitlin__GISP
Mike,
   If you want to do it all inline in the mxml then this works:
<esri:Query id="queryFname" where="Upper(FName) like Upper('%{qTextFname.text}%')">
You should not use text="something" and where="something" at the same time.
MikeJun
Rene, thanks for the quick response.
Robert, thanks a lot again. simple and work great as usual.
