Cancel edit event problem
4605
09-05-2012 03:20 AM
by Anonymous User
Not applicable
Original User: arslansai
hello.
how correct cancel edit event without undo?
sample
private function editLayerStart(event:FeatureLayerEvent):void {       event.preventDefault(); }
don't work
i use editor component
[ATTACH=CONFIG]17487[/ATTACH]
[ATTACH=CONFIG]17488[/ATTACH]
by Anonymous User
Not applicable
i did it.
(EditorSkin)(myEditor.getChildAt(0)).currentState = "normal"
it is reset editor status to normal.
IvanBespalov
By default this event is not cancelable.
FeatureLayerEvent
FeatureLayerEvent () Constructor
public function FeatureLayerEvent(type:String, featureLayer:FeatureLayer = null, cancelable:Boolean = false)
Creates a new FeatureLayerEvent.
Parameters
type:String â?? The event type; indicates the action that triggered the event.
featureLayer:FeatureLayer (default = null) â?? Reference to the associated layer.
cancelable:Boolean (  default = false) â??   Specifies whether the behavior associated with the event can be prevented.
smthing like this:
protected function onSmthingChange(event:SmthingChangeEvent):void
  dispatchEvent(new FeatureLayerEvent(FeatureLayerEvent.EDITS_STARTING, myFeatureLayer, true);
protected function editLayerStart(event:FeatureLayerEvent):void
  if (event.cancelable)
  else
      // undo only
by Anonymous User
Not applicable
Thank you, that's understandable. I can now cancel the event. Another problem - you can tell how to reset the status of the component editor. I'm canceling the event (add an object for example), but the editor does not respond to it. Sign hanging adding an object.
[ATTACH=CONFIG]17509[/ATTACH][ATTACH=CONFIG]17510[/ATTACH]
IvanBespalov
I have not found a legal way to stop/cancel the action started by Editor component.
The only solution that I see - creating your own Editor componet
or remove/add editor each time you prevent start editing :cool:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:esri="http://www.esri.com/2008/ags"
      initialize="application_initializeHandler(event)">
 <s:layout>
  <s:HorizontalLayout/>
 </s:layout>
 <fx:Style>
  @namespace esri "http://www.esri.com/2008/ags";
  esri|Editor
   skin-class: ClassReference("assets.skins.EditorSkin"); /* undo/redo buttons commented */
 </fx:Style>
 <fx:Script>
  <![CDATA[
   import com.esri.ags.components.Editor;
   import com.esri.ags.events.FeatureLayerEvent;
   import com.esri.ags.tasks.GeometryService;
   import mx.events.FlexEvent;
   private var myEditor:Editor;
   private var geometryService:GeometryService = new GeometryService("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
   protected function application_initializeHandler(event:FlexEvent):void
    myEditor = new Editor();
    myEditor.map = myMap;
    myEditor.featureLayers = [ points, fireAreas ];
    myEditor.geometryService = geometryService;
    myEditor.toolbarVisible = true;
    editorHolder.addElement(myEditor);
   protected function editsStartingHandler(event:FeatureLayerEvent):void
    var addingDisabled:Boolean = Math.random() > 0.5;
    if (event.adds && event.adds.length > 0 && addingDisabled && event.cancelable)
     editorHolder.removeAllElements();
 </fx:Script>
 <s:VGroup width="328" height="100%" id="editorHolder" />
 <esri:Map id="myMap" wrapAround180="true">
  <esri:extent>
   <esri:Extent id="sheepfire"
       xmin="-13144000" ymin="4033000" xmax="-13066000" ymax="4099000">
    <esri:SpatialReference wkid="102100"/>
   </esri:Extent>
  </esri:extent>
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
  <esri:FeatureLayer id="fireAreas"
         editsStarting="editsStartingHandler(event)"
         mode="snapshot"
         outFields="*"
         url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/2"/>
  <esri:FeatureLayer id="points"
         mode="snapshot"
         outFields="*"
         url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0"/>
 </esri:Map>
</s:Application>
by Anonymous User
Not applicable
i did it.
