Can't turn features layers on/off - Why?
948
04-25-2011 05:22 AM
WaltBulawa
I have a service with 14 layers.  I would like to be able to selectively turn them on or off.  I'm trying to do this via setting the value of the defaultVisibility variable for the layers but it seems to have no effect.  What do I need to do?  Your help would be very much appreciated.  Here's the code:
<fx:Script>
        <![CDATA[
   import com.esri.ags.Map;
   import com.esri.ags.events.LayerEvent;
   import com.esri.ags.layers.ArcGISDynamicMapServiceLayer;
   import com.esri.ags.layers.Layer;
   import com.esri.ags.layers.supportClasses.LayerInfo;
   import com.esri.viewer.ViewerContainer;
   import mx.rpc.soap.LoadEvent;
   import spark.events.IndexChangeEvent;
   private var myLayer:Layer;
   private var myLayerInfosArray:Array;
            private function init():void
                myLayer = new ArcGISDynamicMapServiceLayer("http://gis.idaho.gov/ArcGIS/rest/services/IdahoParcels6/MapServer");
    myLayer.addEventListener(LayerEvent.LOAD,getLayerInfos);
    map.addLayer(myLayer);
   private function getLayerInfos(event:LayerEvent):void
    var thisLayer:ArcGISDynamicMapServiceLayer = event.layer as ArcGISDynamicMapServiceLayer;
    myLayerInfosArray = thisLayer.layerInfos;
    myLayerInfosArray[0].defaultVisibility = true;
    myLayerInfosArray[1].defaultVisibility = false;//turn off default visible layer
    myLayerInfosArray[2].defaultVisibility = true;
    myLayerInfosArray[3].defaultVisibility = true;
    myLayer.visible=true;
    //myLayer.refresh();
    </fx:Script>
RobertScheitlin__GISP
Walt,
   You turn layers on and off using the visibleLayers property.
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/ArcGISDynamicMapServiceLayer.html
WaltBulawa
I need to do this in the scripting environment (not xml).
Would you know why the myLayer variable (in the code above) does not offer a "visibleLayers" property while the thisLayer variable does have a "visibleLayers" property even though both were defined as ArcGISDynamicMapServiceLayer type variables?
WaltBulawa
Never mind - one was originally defined as an ArcGISDynamicServiceLayer while the other was defined originally as a Layer.  Apparently this makes a lot of difference.
