Can layers with 512x512 and 256x256 sizes in same projection coexist?
1125
02-15-2012 11:49 AM
JoeShmoe
I have a custom WGS84 tile-cache in ArcGIS Server (which I didn't set up).  This tile cache was creating using 256x256 pixel tiles, rather than ArcGIS Online's 512x512 pixel tiles.  We have an existing ESRI-based Silverlight application that uses these custom tiles and ArcGIS Online's layers and it works great.  I am porting this code to Flex, and discovered an issue.  I can add either ArcGIS Online or our custom cache as the only layer in a map without a hitch.  But when I try to add them both, only the first layer added (either ArcGIS Online or ours) appears / functions.
Is this a limitation of the Flex client?  Or could there be something wrong with our conf.xml / LODs?  If so, where can I find a "correct" WGS84 256x256 tiling scheme file that will work with ArcGIS Online?
Nevermind.  I can be done.  We had slightly different numbers in our conf.xml - not sure why.  I extrapolated levels 0 & 1 from ArcGIS Online, fixed our LODs, and it works now.
