Can 2.0 API be used with Flash Builder 3?
1342
08-20-2010 11:24 AM
BrianOevermann
Must one have Flash Builder 4 in order to use the 2.0 API for Flex or can one use Flash Builder 3?  Any 'gotchas' by using version 3 (if it's possible)?
Thanks for the info!
RobertScheitlin__GISP
Brian,
   Yes it is possible. Can't recall the gotcha's right now though. But I don't remember than to be major issues.
BjornSvensson
Esri Alum
Yes, as long as you compile against Flex 4 SDK, you can use whatever IDE you want.
"it is possible to still use Flex Builder 3 if you add Flex 4 SDK support"
http://help.arcgis.com/en/webapi/flex/help/index.html#migrating.htm
BrianOevermann
Thank you Robert and Bjorn.  I suspected that if I ensured compiling with Flex 4 I would be OK.  Thanks, also, for the migrating link, Bjorn.
Brian
