BUG - ArcGIS Viewer for Flex (BETA)
898
07-01-2010 02:37 AM
MarkWells
Playing with the sample http://help.arcgis.com/en/webapps/flexviewer/live/index.html
The zoom slider bar disappears after using the Print widget. Subsequently, some widgets throw errors when opened.
Steps to reproduce:
1) Load http://help.arcgis.com/en/webapps/flexviewer/live/index.html
2) Open Print widget, click Print. Notice the zoom slider disappears from view (although appears on the print)
3) Load each of the remaining widgets in turn
4) Observe script errors (sporadic; and only the first time a given widget is opened)
AndrewHaigh
Another bug / feature....
Using the source version of the ArcGIS Viewer with the config-all.xml configuration.
a) There appears to be no way to close a 'headless' widget once it has been opened.
[INDENT]Would it be better intutaive if when you clicked on the icon in the widget container for a second time that it closed the widget???[/INDENT]
b) Changing <widgetcontainer layout="horizontal|float|vertical|fix"> from horizontal to vertical appears to have no affect - although I may have done something wrong.
Otherwise a step in the right direction!
andrew
