Bing Map Service for Flex 2.0-setup
2611
9
10-04-2010 08:28 PM
JayDira
Can anyone please provide me the steps to add the Bing Map service.
I would like to replace the ESRI images services from the out of the box flex 2.0 with bing map service.
Thanks.
DerekLaw
Esri Esteemed Contributor
Hi JR,
Please see Mehul's detailed post on using Bing maps in the ArcGIS Viewer for Flex in this thread:
How to access Bing Maps
Hope this helps,
JayDira
Hi JR,
Hope this helps,
Hello Law,
I have update my config file and I have no results.
Can you please review the code to let me know what I am missing.
Do I have to include anything about a "VETiledLayer"
Please help.
Thanks.
<configuration>
    <httpproxy enabled="false">proxy.php</httpproxy>
    <title>City of Diamond Bar-Parcel Viewer</title>
    <subtitle>... using ArcGIS</subtitle>
    <logo>assets/images/logo.png</logo>
    <stylesheet>blackgold.swf</stylesheet>
<bing key="AiiqZ2xaaNqzCn7x2sQHE8CvGBLwuDp1Xo-h9D5Cab1ElPgV###########"/>
    <!-- UI elements -->
    <widget left="10"  top="50"    config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/>
    <widget right="-2" bottom="-2" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/>
    <widget right="20" top="55"    config="widgets/MapSwitcher/MapSwitcherWidget.xml" url="widgets/MapSwitcher/MapSwitcherWidget.swf"/>
    <widget left="0"   top="0"     config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/>
    <map initialextent="-13123600 4025400 -13105800 4033950"> top="40">
        <basemaps>
    <layer label="Streets" type="bing" visible="false" style="road" culture="en-US" />
    <layer label="Aerial" type="bing" visible="true" style="aerial" culture="en-US" />
    <layer label="Aerial with labels" type="bing" visible="false" style="aerialWithLabels" culture="en-US" />
<basemaps>
DerekLaw
Hi JR,
  <map initialextent="-13123600 4025400 -13105800 4033950"  > top="40">
Noticed this typo in your <map> tag, you need to remove the extra ">".
Hope this helps,
JayDira
Hi JR,
Hope this helps,
Hello Law,
I fixed that typo and I still recieve a blank screen. Any idea's what can be the issue.
I know the key works because we are using bing map  on our .net maps.
Thanks.
DasaPaddock
Are you using Viewer 2.1 or an earlier version?
JayDira
I am using Viewer 2.1 now.
DasaPaddock
If you use a tool like HttpFox, do you see any requests going to http://dev.virtualearth.net and if so, what is the response?
AndrewLuzinov
How can i get the list of available LODs for VETiledLayer?
I'm trying to write custom zoom navigation control.
