Basemap Switcher - Slider
2259
07-28-2011 07:39 AM
RobertMueller
I've taken the code (below) from a previous post (http://forums.arcgis.com/threads/190...t=slider+alpha) that was trying to implement a basemap slider of sorts as found in this website; http://maps.hamiltontn.gov/hcflex/
My question is concerning the placement of this code. This code should be in a widget, similar to the original BaseMap switcher, although evidently lacks the correct "hook" into the map extent. However if put the code into the HeaderControllerWidget, a seperate map appears, but the code works. Can anyone fill in my gap of understanding?
Bob
<esri:Map id="MaryMap">
<esri:ArcGISTiledMapServiceLayer
visible="true"
url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
visible="true"
alpha="{Math.max(1-mapTrans.value)}"
url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer" />
visible="true"
alpha="{Math.min(mapTrans.value-1)}"
url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer" />
</esri:Map>
<s:Group left="10" right="10" top="10" bottom="10">
<s:VSlider
id="mapTrans" width="10"
minimum="0" maximum="2"
snapInterval=".1"
value="1"
liveDragging="true" x="10" y="58">
</s:VSlider>
<s:ToggleButton x="10" y="5" label="Aerial" width="54" height="46"
id="aerialButton"
click="{mapTrans.value=0}" chromeColor="#1293BE"
toolTip="Aerial Photo"/>
<s:ToggleButton x="74" y="5" label="Base Map" width="54" height="46"
id="baseButton"
click="{mapTrans.value=1}"
toolTip="Base Map"/>
<s:ToggleButton x="145" y="5" label="Topo" width="54" height="46"
id="topoButton"
click="{mapTrans.value=2}"
toolTip="Topo Map"/>
</s:Group>
