AutoComplete on textInput
819
04-15-2010 10:07 AM
CaseyBentz
I have been working on getting the Yahoo Astra AutoCompleteManager to work.  I have an httpService that runs and populates the dataprovider for the AutoCompleteManager.  This all works perfectly, except that when I get the pop up to open, and the list is long enough to have the vertical scroll bar appear, and type end/home, I get this error message.  Otherwise, this tool works perfect.  I would like to listen for the mouse click event on an item, but other than that it seems pretty good.  Any help would be great.
Casey
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at mx.controls.listClasses::ListBase/itemRendererToIndex()
at com.yahoo.astra.mx.managers::AutoCompleteManager/keyDownHandler()
TabrezQuazi
Casey,
Can you post the code, that will help us understand what the exact problem is..
One other reason for the exception could be that the dataprovider has a null in the list.
Add a filterFunction to remove any null values in the dataproviders list.
Tabrez Nadeem.
CaseyBentz
I have attached my code and the SQL string from my web service.  I added the is not null, and it did not help.  So, I assume that I do not have any null values.
I also tried to use the same textInput for each of my search options, I do not want the autocomplete enabled when the other search options are chosen.  I could not get it to work, so I went with a second textInput and this works.  I do not like it but it works.
Also, I cannot get the pop up list to be sorted alphabetically, I would have thought that if the returned XML was in alphabetical order, the list would be too.
SELECT DISTINCT SUBDIVNAME FROM GIS.SubdivisionBoundaries WHERE SUBDIVNAME <> '' AND SUBDIVNAME <> ' ' AND SUBDIVNAME IS NOT NULL ORDER BY SUBDIVNAME
<?xml version="1.0" encoding="utf-8"?>
<mx:FormItem xmlns:mx="http://www.adobe.com/2006/mxml" label="Select Search Type:" styleName="BannerStatus" xmlns:yahoo="http://www.yahoo.com/astra/2006/mxml">
<mx:Script>
  <![CDATA[
   import com.events.SearchEvent;
   import com.model.Model;
   private function init():void{
    if (searchType.selectedValue == "Subdivision"){
     textSearch.visible = false;
     textSearch.includeInLayout = false;
     subSearch.visible = true;
     subSearch.includeInLayout = true;
     subSearch.setFocus();
    else{
     textSearch.visible = true;
     textSearch.includeInLayout = true;
     subSearch.visible = false;
     subSearch.includeInLayout = false;
     textSearch.setFocus();
</mx:Script>
<mx:Binding source="textSearch.text"
  destination="subSearch.text"/>
<mx:Binding source="subSearch.text"
  destination="textSearch.text"/>
<yahoo:AutoCompleteManager id="autoComplete"
  dataProvider="{Model.instance.subdivisionXML.subdivision}"
  labelField="SUBDIVNAME"
  target="{subSearch}"
  minCharsForCompletion="4"
  wordWrap="true"/>
<mx:RadioButtonGroup id="searchType"/>
<mx:HBox width="100%" height="100%">
  <mx:RadioButton groupName="searchType" label="Service Point" styleName="BannerStatus" selected="true" click="init();"/>
  <mx:RadioButton groupName="searchType" label="Gisonumber" styleName="BannerStatus" click="init();"/>
  <mx:RadioButton groupName="searchType" label="Fuse or Switch" styleName="BannerStatus" click="init();"/>
  <mx:RadioButton groupName="searchType" label="Workorder Number" styleName="BannerStatus" click="init();"/>
  <mx:RadioButton groupName="searchType" label="Subdivision" styleName="BannerStatus" click="init();"/>
  <mx:TextInput id="textSearch" width="200" styleName="TextInput"
   enter="dispatchEvent( new SearchEvent(searchType.selectedValue.toString(), textSearch.text, SearchEvent.SEARCH_EVENT))"
   creationComplete="init();"/>
  <mx:TextInput id="subSearch" visible="false" includeInLayout="false" width="200" styleName="TextInput"
  <mx:Button label="Search" click="dispatchEvent( new SearchEvent(searchType.selectedValue.toString(), textSearch.text, SearchEvent.SEARCH_EVENT))" styleName="Button"/>
</mx:HBox>
</mx:FormItem>
