Attribute Inspector View Popup
3044
13
01-13-2012 06:46 AM
AnthoniLlau
Hi all,
I'm a newbie to API for Flex with an issue when clicking on a feature layer. When clicking, I get an [object Object] result for the field I have selected. The code is below. Any guidance on what modifications are needed is greatly appreciated. I highlighted the code section where it is having the problem.
Tony
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:esri="http://www.esri.com/2008/ags"
pageTitle="Attribute Inspector (edit)">
This application is "ViewOnly" and connects to a non-editable layer.
This application allows user to click on a feature (parcels)
and view a few attributes of that feature.
This is done by clicking a point on the map to select feature(s)
from the FeatureLayer.
The AttributeInspector then displays the selection in the InfoWindow
popup which is shown where user clicked the map.
Note that this sample displays the FeatureLayer in "selection" mode and
that the parcels are actually displayed using a dynamic layer pointing to
the matching map service.
<fx:Script>
<![CDATA[
import com.esri.ags.events.FeatureLayerEvent;
import com.esri.ags.events.MapMouseEvent;
import com.esri.ags.geometry.MapPoint;
import mx.controls.Alert;
import mx.rpc.events.FaultEvent;
protected function map_mapClickHandler(event:MapMouseEvent):void
// set the selection query based on the click
queryMapClick.geometry = event.mapPoint;
myFeatureLayer.selectFeatures(queryMapClick); // default selectionMethod is FeatureLayer.SELECTION_NEW
myMap.infoWindow.hide();
protected function attrInsp_faultHandler(event:FaultEvent):void
Alert.show(event.fault.message, "Fault");
protected function myFeatureLayer_selectionCompleteHandler(event:FeatureLayerEvent):void
// only show infoWindow if a feature was found
if (event.featureLayer.numGraphics > 0)
myMap.infoWindow.label = "Zip Code " + event.featureLayer.selectedFeatures[0].attributes; myMap.infoWindow.show(queryMapClick.geometry as MapPoint);
else
Alert.show("Sorry found nothing here...");
</fx:Script>
<fx:Declarations>
<esri:Query id="queryMapClick"/>
</fx:Declarations>
<fx:Style>
@namespace s "library://ns.adobe.com/flex/spark";
@namespace esri "http://www.esri.com/2008/ags";
esri|InfoWindow
background-color: #0066FF; /* dark khaki */
border-color: #000000;
border-thickness: 3;
lower-left-radius: 20;
lower-right-radius: 20;
upper-left-radius: 20;
upper-right-radius: 0;
padding-bottom: 7;
padding-left: 7;
padding-right: 7;
padding-top: 4;
esri|InfoWindowLabel
color: #FFFFFF;
font-size: 15;
padding-left: 120;
s|BorderContainer
background-color: #F0E68C; /* light khaki */
corner-radius: 15;
content-background-color: #BDB76B;
padding-bottom: 5;
</fx:Style>
<s:layout>
<s:VerticalLayout/>
</s:layout>
<esri:Map id="myMap"
load="attrInsp.featureLayers = [myFeatureLayer]"
mapClick="map_mapClickHandler(event)"
openHandCursorVisible="false">
<!-- Extent for Dade County -->
<esri:extent>
<esri:Extent xmin="767247" ymin="346748" xmax="954385" ymax="609584">
<esri:SpatialReference wkid="2236"/>
</esri:Extent>
</esri:extent>
<esri:ArcGISDynamicMapServiceLayer url="http://dohswebchd1301/ArcGIS/rest/services/Test/Pool_Drownings_1_-_4_Years_2005_-_2010/MapServer"/>
<esri:FeatureLayer id="myFeatureLayer"
mode="selection"
outFields="[ZIP_INDICATORS.ZIP,Sheet1$.Total]"
selectionColor="0x000000"
selectionComplete="myFeatureLayer_selectionCompleteHandler(event)"
url="http://dohswebchd1301/ArcGIS/rest/services/Test/Pool_Drownings_1_-_4_Years_2005_-_2010/MapServer/0"/>
<esri:infoWindowContent>
<s:BorderContainer>
<esri:AttributeInspector id="attrInsp"/>
</s:BorderContainer>
</esri:infoWindowContent>
</esri:Map>
<s:Label text="The feature layer has {myFeatureLayer.selectedFeatures.length} selected feature(s)."/>
</s:Application>
RobertScheitlin__GISP
Tony,
   That makes perfect sense as you can not use a fields value if you do not tell the featurelayer to return results for that field.
Here is what you have to do to eliminate the zip from the attribute inspector results:
<esri:infoWindowContent>             <s:BorderContainer>                 <esri:AttributeInspector id="attrInsp"                                          formItemsOrder="fieldInspector"                                          featureLayers="{[myFeatureLayer]}">                     <esri:FieldInspector featureLayer="{myFeatureLayer}"                                          fieldName="parcels2.NAME"                                          label="Parcel Owner Name"/>                     <esri:FieldInspector featureLayer="{myFeatureLayer}"                                          fieldName="PPIN"                                          label="Parcel ID Number"/>                     <esri:FieldInspector featureLayer="{myFeatureLayer}"                                          visible="false"                                           fieldName="parcels2.ZIPCODE_1"                                          label="Zip Code"/>                 </esri:AttributeInspector>             </s:BorderContainer>         </esri:infoWindowContent>
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
Anthoni,
   You are not specifying which attribute you want...
myMap.infoWindow.label = "Zip Code " + event.featureLayer.selectedFeatures[0].attributes["FieldName"];
AnthoniLlau
Anthoni,
Thanks for the quick response.
I tried as you suggested, but now it is giving me an "undefined" result.
Anthoni,
   You did replace "Field Name" with your actual field name that you are trying to you right?
AnthoniLlau
Anthoni,
Yes. I used the last field name of those shown below.
Fields:
ZIP_INDICATORS.FID (Type: esriFieldTypeOID, Alias: FID)
ZIP_INDICATORS.Shape (Type: esriFieldTypeGeometry, Alias: Shape)
ZIP_INDICATORS.AREA (Type: esriFieldTypeDouble, Alias: AREA)
ZIP_INDICATORS.PERIMETER (Type: esriFieldTypeDouble, Alias: PERIMETER)
ZIP_INDICATORS.ZIP (Type: esriFieldTypeDouble, Alias: ZIP)
Anthoni,
  So your code looks like this than:
myMap.infoWindow.label = "Zip Code " + event.featureLayer.selectedFeatures[0].attributes["ZIP_INDICATORS.ZIP"];
AnthoniLlau
Anthoni,
Yes it does. Is it attempting to search for a default variable type (e.g. string)?
Tony,
   I got this code to work perfectly using one of my joined map services:
    <fx:Script>
        <![CDATA[
                    myMap.infoWindow.label = "Zip Code " + event.featureLayer.selectedFeatures[0].attributes["parcels2.ZIPCODE_1"];
                else
    </fx:Script>
    <fx:Declarations>
    </fx:Declarations>
    <fx:Style>
        esri|InfoWindow
            padding-bottom: 7;
            padding-left: 7;
            padding-right: 7;
            padding-top: 4;
            color: #FFFFFF;
            font-size: 15;
            padding-left: 120;
        s|BorderContainer
            corner-radius: 15;
            padding-bottom: 5;
    </fx:Style>
    <s:layout>
        <s:VerticalLayout/>
    </s:layout>
        <!--<esri:extent>
            </esri:Extent>
        </esri:extent>-->
        <esri:ArcGISDynamicMapServiceLayer url="http://gislap134/ArcGIS/rest/services/Join_Test/MapServer"/>
                           mode="selection"
                           outFields="[parcels2.NAME,PPIN,parcels2.ZIPCODE_1]"
                           url="http://gislap134/ArcGIS/rest/services/Join_Test/MapServer/0"/>
            <s:BorderContainer>
    </esri:Map>
</s:Application>
You need to check your map service and see if the join took correctly. I am concerned with a field name like Sheet1$.Total sounds like you have joined an excel spreadsheet and that will be questionable is the ArcGIS SOC account will have access to that spreadsheet.
AnthoniLlau
Thanks Robert. I did join it with an excel spreadhseet.
I'll go back to fix this and give you an update. Thanks for all your help.
Tony
AnthoniLlau
I removed the join it works much better but not perfect as of yet.
It displays the zip code only when I place that variable in the outfields. However, when doing so it repeats itself (both in the heading and again with the other field (drownings). If I don't place the variable in the outfields it still appears as undefined.
Here is the code I'm currently using. I highlighted the pertinent code in red.
Tony
pageTitle="Attribute Inspector (edit)" xmlns:mx="library://ns.adobe.com/flex/mx">
<fx:Script>
<![CDATA[
myMap.infoWindow.label = "Zip Code: " + event.featureLayer.selectedFeatures[0].attributes.["ZIP"]; myMap.infoWindow.show(queryMapClick.geometry as MapPoint);
else
</fx:Script>
<fx:Declarations>
</fx:Declarations>
<fx:Style>
esri|InfoWindow
background-color: #0066FF; /* blue */
border-thickness: 2;
lower-left-radius: 10;
lower-right-radius: 10;
upper-left-radius: 10;
padding-bottom: 7;
padding-left: 7;
padding-right: 7;
padding-top: 4;
color: #FFFFFF;
font-size: 15;
padding-left: 10;
s|BorderContainer
corner-radius: 15;
padding-bottom: 5;
</fx:Style>
<s:layout>
<s:VerticalLayout/>
</s:layout>
<esri:extent>
</esri:Extent>
</esri:extent>
<esri:ArcGISDynamicMapServiceLayer url="http://dohswebchd1301/ArcGIS/rest/services/Test/Pool_Drownings1-4Years0510/MapServer"/>
mode="selection"
outFields="[ZIP,Drownings]" selectionColor="0x000000"
url="http://dohswebchd1301/ArcGIS/rest/services/Test/Pool_Drownings1-4Years0510/MapServer/1"/>
<s:BorderContainer>
</esri:Map>
</s:Application>
