Attribute Inspector Problem
3329
03-20-2014 06:23 AM
HectorChapa
I am try to learn how to use attribute inspector but the problem is I dont understand why this doesnt work on point layer. I know this code works for polygons. I know is something simple to change to make it work with points layer I just don't know where.
Can anyone help me to fix the following code.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:esri="http://www.esri.com/2008/ags"
      pageTitle="Attribute Inspector outside the Map">
 Description:
 This sample demonstrates how you can use the AttributeInspector outside of
 an InfoWindow.
 The AttributeInspector can be placed anywhere.  Most samples show it
 inside the InfoWindow, but it can also be in a floating panel, or beneath
 the map - as in this example.
 The AttributeInspector gets it content from the selection of the feature
 layers that it is connected with.
 <esri:AttributeInspector featureLayers="{[fLayer]}"/>
 Selection by map click versus selection by rectangle:
 There are multiple ways to catch user input.
 If you want people to select feature using a rectangle, the easiest way
 is to use the DrawTool with the EXTENT draw type.
 To select features by clicking on the map, use either:
 a) the mapClick event on the map, or
 b) the DrawTool with the MAPPOINT draw type.
 Documentation:
 For more information, see the API documentation.
 https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/components/AttributeInspector.html
 https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/components/supportClasses/FieldInspector.html
 https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/events/AttributeInspectorEvent.html
 https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/layers/FeatureLayer.html
 <s:layout>
  <s:VerticalLayout gap="0"/>
 </s:layout>
 <fx:Script>
  <![CDATA[
   import com.esri.ags.Graphic;
   import com.esri.ags.SpatialReference;
   import com.esri.ags.events.AttributeInspectorEvent;
   import com.esri.ags.events.DrawEvent;
   import com.esri.ags.events.GraphicEvent;
   import com.esri.ags.events.MapMouseEvent;
   import com.esri.ags.geometry.Extent;
   import mx.controls.Alert;
   import mx.rpc.events.FaultEvent;
   private function select_clickHandler():void
    myDrawTool.activate(DrawTool.EXTENT);
   private function clear_clickHandler():void
    highlightGraphicsLayer.clear();
    fLayer.clearSelection();
   protected function map_mapClickHandler(event:MapMouseEvent):void
    // set the selection query based on the click
    queryByGeometry.geometry = event.mapPoint;
    fLayer.selectFeatures(queryByGeometry); // default selectionMethod is FeatureLayer.SELECTION_NEW
   private function attributesinspector_showFeatureHandler(event:AttributeInspectorEvent):void
    var g:Graphic = new Graphic(event.feature.geometry);
    g.toolTip = event.feature.toolTip;
    highlightGraphicsLayer.add(g);
   private function drawEndHandler(event:DrawEvent):void
    // const myDrawTool:DrawTool = event.target as DrawTool;
    myDrawTool.deactivate();
    if (event.graphic.geometry is Extent)
     queryByGeometry.geometry = event.graphic.geometry;
   private function fLayer_faultHandler(event:FaultEvent):void
    Alert.show(event.fault.faultString + "\n\n" + event.fault.faultDetail, "FeatureLayer error " + event.fault.faultCode);
   private function zoomToNorthCarolina():void
    var northCarolinaExtent:Extent = new Extent(-9374000, 3987000, -8409000, 4386000, new SpatialReference(102100));
    myMap.extent = northCarolinaExtent;
    // make sure the whole extent is visible
    if (!myMap.extent.contains(northCarolinaExtent))
     myMap.level--;
   protected function fLayer_graphicAddHandler(event:GraphicEvent):void
    // add tool tips
    event.graphic.toolTip = event.graphic.attributes.NAME;
   protected function getFeatureCount(value:Array):int
    return value.length;
 </fx:Script>
 <fx:Declarations>
  <esri:Query id="queryByGeometry"/>
  <esri:DrawTool id="myDrawTool"
        drawEnd="drawEndHandler(event)"
        map="{myMap}"/>
  <esri:SimpleFillSymbol id="countySymbol" alpha="0.2">
   <esri:SimpleLineSymbol width="3" color="0xEEEEEE"/>
  </esri:SimpleFillSymbol>
  <esri:SimpleMarkerSymbol id="defaultsym"  alpha="1" color="#726E6D" style="circle" size="24" >
  </esri:SimpleMarkerSymbol>
 </fx:Declarations>
 <s:controlBarContent>
  <s:RichText width="100%">
   an InfoWindow.  The AttributeInspector can be placed anywhere.  Most samples show it
  </s:RichText>
 </s:controlBarContent>
 <esri:Map id="myMap"
     load="zoomToNorthCarolina()"
     mapClick="map_mapClickHandler(event)"
     wrapAround180="true">
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
  <esri:FeatureLayer id="fLayer"
         fault="fLayer_faultHandler(event)"
         graphicAdd="fLayer_graphicAddHandler(event)"
         mode="snapshot"
         outFields="*"
         symbol="{defaultsym}"
         url="http://67.78.127.3:6080/arcgis/rest/services/STEARWEBMAPTEST/FeatureServer/0"/>
  <esri:GraphicsLayer id="highlightGraphicsLayer"/>
 </esri:Map>
 <s:Group width="100%" height="240">
  <s:Rect width="100%" height="100%">
   <s:fill>
    <s:SolidColor color="#D3D1D1"/>
   </s:fill>
  </s:Rect>
  <s:HGroup width="100%" height="240"
      paddingLeft="6">
   <s:BorderContainer backgroundColor="0xEEEEEE"
          borderColor="0xCECECE"
          borderWeight="2"
          contentBackgroundColor="0xEEEEEE"
          cornerRadius="5"
          minWidth="200"
          visible="{getFeatureCount(fLayer.selectedFeatures) > 0}">
    <esri:AttributeInspector id="attributeInspector"
           left="6" right="6" top="6" bottom="6"
           showFeature="attributesinspector_showFeatureHandler(event)">
     <esri:FieldInspector featureLayer="{fLayer}"
           fieldName="StateID"
           label="County Name"/>
           fieldName="ZipCode"
           label="Median Age"/>
           fieldName="FullAddres"
           label="Women"/>
           fieldName="AddressUni"
           label="Men"/>
           fieldName="PhoneNumbe"
           label="FIPS"/>
    </esri:AttributeInspector>
   </s:BorderContainer>
   <s:VGroup width="50%" height="100%">
    <s:Button id="extentButton"
        click="select_clickHandler()"
        label="Select by Extent"/>
    <s:Button click="clear_clickHandler()" label="Clear Selection"/>
    <s:Rect width="1" height="5"/>
    <s:Label width="100%"
       fontStyle="italic"
       text="Select a county by clicking on it on the map, or use the 'Select by Extent' button to select multiple counties.  The attribute inspector will reflect the current selection."/>
   </s:VGroup>
  </s:HGroup>
 </s:Group>
</s:Application>
KomanDiabate
Looks Like it's working...
[ATTACH=CONFIG]32368[/ATTACH]
HectorChapa
Really wow in my machine I dont see that display.
