Attribute Inspector in Mobile Flex
1518
07-23-2013 08:28 AM
MattSheehan
I'm having a bit of a brain fart. I am updating an attribute inspector with current lat/long using the following code:
for each(var updateatts:* in (list.dataProvider as ArrayList).source)
    if((updateatts as FormField).label == "Longitude")
 (updateatts as FormField).feature.attributes["Longitude"] = 1.0;
 dispatchEvent(new AttributeInspectorEvent(UPDATE_FEATURE, false, (updateatts as FormField).featureLayer, (updateatts as
         FormField).feature));
I'd like the form (see attached) to dynamically updated with this new data. Any good suggestions?
I should add when we close the attribute inspector, then reopen the data is updated. I'd like the update to occur without the need to close the inspector window.
--Rory
YannCabon
Try
for each(var updateatts:FormField in (list.dataProvider as ArrayList).source)
    if(updateatts.label == "Longitude")
 updateatts.feature.attributes["Longitude"] = 1.0;
 dispatchEvent(new AttributeInspectorEvent(UPDATE_FEATURE, false, updateatts.featureLayer, updateatts.feature));
         updateatts.dispatchEvent(new FormFieldEvent(FormFieldEvent.DATA_CHANGE));
MattSheehan
That worked. Thanks Yann.
