ArcGISImageServiceLayer Time Error
956
10-31-2011 04:00 AM
GlenReid
When I use an image service in mxml like so:
<esri:ArcGISImageServiceLayer id="esriImageLayer" imageFormat="png8" visible="false"
           url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/World/MODIS/ImageServer"/>
everything works OK with the layer and timeSlider.  When I create the layer in actionscript:
var lyr:ArcGISImageServiceLayer = new ArcGISImageServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/World/MODIS/ImageServer");
lyr.imageFormat = "png8";
lyr.visible = true;
timeSlider.createTimeStopsByTimeInterval(lyr.timeInfo.timeExtent, 1, TimeInfo.UNIT_MONTHS);
timeSlider.visible = true;
I get an error on the createTimeStopsByTimeInterval line:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
Any idea as to what I'm missing here?
Glen
IvanBespalov
lyr.timeInfo is NULL
Because layer is not loaded yet.
1 - Add layer to map:
map.addLayer(lyr);
or dispatch Layer load event (if you do not want to add layer to your map)
lyr.dispatchEvent(new LayerEvent(LayerEvent.LOAD, lyr));
2 - listen LayerEvent:
lyr.addEventListener(LayerEvent.LOAD, onLayerLoad, false, 0, true);
lyr.addEventListener(LayerEvent.LOAD_ERROR, onLayerLoadError, false, 0, true);
protected function onLayerLoad(event:LayerEvent):void
    //get lyr.timeInfo here
protected function onLayerLoadError(event:LayerEvent):void
    //trace error
GlenReid
Thanks Ivan, that was the issue.
