ArCGIS Server 10.1 and Older ESRI Flex Library
1389
10-10-2012 10:11 AM
ionarawilson1
I have a FLEX application created with the 2.2 ESRI Library. Will my application break if I transfer it to ArcGIS Server 10.1?
BjornSvensson
Esri Alum
Probably not.
The only forward-compatibility issue in the Flex API I'm aware of is using 1.x to connect to a tiled map service that is from a 10.1 service, but if you are using 2.2 then you should be fine.  However, this is not a use case we have tested extensively.
ionarawilson1
Thank you Bjorn. I will transfer the application and will post again if any issues arise! Cheers!
