ArcGIS Dynamic Layer and Load Event
3042
08-31-2011 04:02 PM
ZahidChaudhry
I have a dynamic layer that takes little longer to load. I want to show a busy cursor until everything is displayed on the map. I have tried, load, render, creationcomplete event, but no luck..any suggestions..
ZahidChaudhry
Still no Luck...I thought may be someone from ESRI will be able to Help...
BjornSvensson
You're probably looking for the updateStart/updateEnd events on the Layer class.  They are listed in the API Reference under http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/ArcGISDynamicMapServiceLayer.html#e... and there is a sample for events called EventBasics.mxml that might help (it was part of the the API Library download) and can be seen in action at http://help.arcgis.com/en/webapi/flex/samples/index.html#/Events/01nq00000019000000/.
Hope this helps.
ZahidChaudhry
Thanks Bjorn.
