ArcGIS API for Flex 2.0 Beta is now available
6738
15
02-05-2010 06:34 AM
BjornSvensson
Esri Alum
The Flex API 2.0 beta is now available at http://resourcesbeta.esri.com/content/arcgis-api-flex
If you don't read any other documentation, you might want to
at least read these "Three Potential Initial Gotchas":
1. Requires Adobe Flex 4 SDK.
2. You should use Flash Builder 4 beta 2 as your IDE.
3. If connecting to a 9.3 server, you need to set the useAMF property to false for Query, Geoprocessor and FeatureLayer.
RoyceSimpson
Thanks guys!
RoyceSimpson
Are there any samples available for the new Clusterer functionality?
BjornSvensson
Esri Alum
In the API Library download (the "zip") is a rough/draft cluster sample called ClusterFunction.mxml.  We haven't included it in the list/TOC of samples online because our clustering implementation is still a bit rough and the sample isn't that great.  There might be a few API changes to the first beta when it comes to clustering ...
To see the samples, either compile it in FlashBuilder or go to:
http://help.esri.com/en/webapi/flex/samples/index.html?sample=ClusterFunction
Any feedback on clustering is most welcome.  Before the final release we will have documentation and more samples.
RoyceSimpson
RoyceSimpson
I see ClosestFacility.mxml and the next one is CustomLODS.mxml.
BjornSvensson
Esri Alum
Sorry my bad - that was an old sample.  I've removed it.
BjornSvensson
Esri Alum
The sample is called FeatureLayerClustering and you can see it in action at http://help.esri.com/en/webapi/flex/samples/index.html?sample=FeatureLayerClustering
AlexYule
Just noticed a bug on that, and possibly all the sample pages.
Try moving the mouse from the TOC panel over onto the map. Bam, scroll bars appear! Even worse if you move the mouse into the map pane from the bottom. If you do it slow enough, the scrollbar flickers on and off a million times until you've passed through! Perhaps related to the problem I'm having? (see most recent thread)
BjornSvensson
Esri Alum
Yes, that is a problem with how we are presenting the individual samples inside our Samples Explorer in regards to those scrollbars.  For now, you can also go straight to the sample in action by going directly to the SWF.
For example, instead of
go to
http://help.esri.com/en/webapi/flex/samples/FeatureLayerClustering.swf
