Arc GIS FLex Viewer 1.3 map not published
682
09-13-2010 07:00 AM
RamakrishnaBillakanti
I'm a graduate student working on FLEX Viewer 1.3 interface with 9.3.1 Sever installation. I've downloaded the sameple Flex Viewer Application for the ESRI Website and I'm modifying the link to ESRI Map services to the map services which I've created. I've replaced the map hyperlink with the hyperlink of the rest service which I've created in the config file. But unfortunately it doesn't show any map from my service. Do I need to configure any thing else before I change and publish it. Also I published it using as the DynamicMapService it worked perfectly but was trying to have tools configured to it.
Also I got one more question is Mapservice different from ArcGISDynamicMapServiceLayer, if they are not same how would i convert my published to mapservice.
Thank you
Ramakrishna
