appending variables in a query
995
07-29-2010 10:51 AM
DebbieJamieson
I can create a query with mulitple variables just fine if I hardcode all of them...
  <esri:Query id="query"  where="STATE_NAME = 'Texas' and pop1990 &lt; 1000000" text="{qCityName.text}" returnGeometry="true" outSpatialReference="{map.spatialReference}">
BUT, I want to use the users input of State value and can't figure out how to append it, I have tried..
       <esri:Query id="query"  where="STATE_NAME = '" + "{qStateName.text}" + "' and pop1990 &lt; 1000000"  returnGeometry="true" outSpatialReference="{map.spatialReference}">
      <esri:Query id="query"  where="STATE_NAME = '"  & "{qStateName.text}" & "' and pop1990 &lt; 1000000"  returnGeometry="true" outSpatialReference="{map.spatialReference}">
but get syntax errors. Any ideas???
thanks
ReneRubalcava
Esri Frequent Contributor
If you're using the where clause, I don't think you need the text property. It's not your error though.
<esri:Query id="query" where="STATE_NAME = '{qStateName.text}' and pop1990 &lt; 1000000" returnGeometry="true" outSpatialReference="{map.spatialReference}">
FlashBuilder makes it look like you're passing regular text, but you're really binding it to the input.
EokNgo
thanks
I believe the issue is in your where clause. The whole where statement should be a single text string:
where="'STATE_NAME = ' + {qStateName.text} + ' and pop1990 &lt; 1000000'"
Try that.
