API for Flex tutorial
6448
8
02-13-2014 07:36 AM
DustinHolt
I'm doing a tutorial on the API for Flex using flash builder and I'm having a problem. In this exercise I'm creating a cached map service with a tiled map service as the base map, and setting the extent. I have followed the tutorial to the tea, but I keep getting "Object is not assigned". Can anyone see where I'm going wrong.
by Anonymous User
Not applicable
Original User: rscheitlin
Dustin,
   You will notice (upon close observation) that the changes I indicated are included in the exercise steps.
and give it an ???id??? of ???louisville???.
load="{map.extent = louisville.fullExtent}"
Flex is a case sensitive language so you have to be very cautious of that fact.
by Anonymous User
Not applicable
Original User: [email protected]
Dustin,
I cannot see where the louisville extent is being set, try removing the load="map.extent = louisville.fullextent"
Regards
Anthony
DustinHolt
It works now, I don't now why they tried to do it that way. Thanks
by Anonymous User
Not applicable
Dustin,
  Where is this Flex Tutorial located?
If your code looks like this it works fine:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark"
               xmlns:mx="library://ns.adobe.com/flex/mx"
               xmlns:esri="http://www.esri.com/2008/ags"
               minWidth="955" minHeight="600">
    <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
    </fx:Declarations>
    <esri:Map id="map">
        <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/>
        <esri:ArcGISDynamicMapServiceLayer id="louisville" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer" load="{map.extent = louisville.fullExtent}"/>
    </esri:Map>
</s:Application>
DustinHolt
Here is a PDF of the exercise.
by Anonymous User
Not applicable
Dustin,
DustinHolt
I found where I went wrong now. I had the "load="{map.extent = louisville.fullExtent}"/>" as a separate line, when it should have been a part of the "<esri:ArcGISDynamicMapServiceLayer" line.
Thanks Robert
by Anonymous User
Not applicable
Dustin,
   I went back and returned the answer credit to Anthony as he was the one that originally answered your question. I just wanted to add additional questions and comments, not take his points.
DustinHolt
Yes, Thanks Anthony.
