API 2.0 - Cursor issue with map context menu
3197
12
06-29-2010 10:57 AM
TonyCollins
Hi there,
Using API 2.0, the standard context menu (on right click) has no mouse pointer when in pan mode (NavigationTool.PAN).
Is this something I am doing/can be fixed?
Tony
TonyCollins
Thanks Dasa,
Hope Adobe come up with something for that.
On a side note, is there a way to stop your API using the cutom cursor when in pan mode?
This seems to be a new Flash Player 10.1 bug that only happens in IE. If a custom cursor is being shown, and you right click, then the system cursor is supposed to be shown, but in FP 10.1 it isn't, so you're left with no cursors. This is happening for 1.x apps too.
I've submitted this bug to Adobe at https://bugs.adobe.com/jira/browse/SDK-26818
A workaround is to set the wmode to opaque, but only for IE since Chrome will show both cursors otherwise.
e.g. In the html template add this after params.allowfullscreen = "true";
if (swfobject.ua.ie && swfobject.ua.win) // http://code.google.com/p/swfobject/wiki/api
    params.wmode = "opaque"; // workaround for cursor issue - https://bugs.adobe.com/jira/browse/SDK-26818
DasaPaddock
Are you looking for this, or do you mean the hand that's shown while you're panning?
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/Map.html#openHandCursorVisible
TonyCollins
Ahh, that's great...
I'm going to stick with this until the fix for the right-click is resolved as we need to use a cuctom context menu.
Thanks Dasa!
