Any solution to get an address by location in Bing Map?
3857
08-26-2012 11:33 AM
ChenfengXiong
I can only find a function called "addressToLocations" in VEGeoCoder, is there any way to do it inversely like "LocationToAddress" ?
Any suggestions?
Drew
Any suggestions?
I don't see anything in the ESRI API, but BING has its own REST endpoint you can hit using HTTP.
Below is the docs to get an address by XY coordinate..
http://msdn.microsoft.com/en-us/library/ff701710
Drew
Drew
Any suggestions?
Drew
ChenfengXiong
OK, although this is a little bit complex, It works. Thanks!
