AlivePDF - result displays request instead of Title of PDF
1413
5
06-15-2010 06:54 AM
CarmenDurham
Hello all,
I am using AlivePDF and have the resulting document displaying the content with no problems.
But the tab in IE displays:  "http://myserver/createPDF/create.aspx?name=AddressReport.pdf&method=inline"
instead of something like Address Report.
What/where can I change it so that the tab will read "Address Report" or AddressReport.pdf?  Also, when I try a "file/Save As", it wants to save the file to "create.pdf" instead of "AddressReport.pdf"
Any ideas?  I tried a couple of things in the .mxml (.setTitle for the PDF) and in the createPDF app folder, but they didn't work.
Carmen
LeonScott
Carmen,
In your .aspx page, you can put this line of code in the Page_Load function...
Page.Title = "Address Report"
to change the tab in IE. This worked for me.
I noticed the default name of the pdf will be the same as the name of your .aspx page. Mine has a default name of "default". So you could rename your page to AddressReport.aspx, as a work around. I haven't figured out another way to do that.
Leon
CarmenDurham
Leon,
Thank you for responding.
I renamed the .aspx and aspx.cs so that at least the "save as" works a little better per your suggestion.
I have added Page.Title = "Address Results" to the Page_Load event, but it still doesn't work.  I tried various locations.  Here is what my page_load event looks like.  Will you please compare it with yours?  I have even tried setting name="Address Results".
Also, what version of AlivePdf are you using?  I have 1.4.9.
   protected void Page_Load(object sender, EventArgs e)
                Page.Title = "Address Search";
                string method = Request.QueryString["method"];
     string name = Request.QueryString["name"];
     byte[] data = Request.BinaryRead(Request.TotalBytes);
     Response.ContentType = "application/pdf";
     Response.AddHeader("Content-Length", data.Length.ToString());
     Response.AddHeader("Content-disposition", method + "; filename=" + name);
     Response.BinaryWrite(data);
     Response.End();
I know very little about asp.net so if I am missing something obvious, I apologize.
Carmen
LeonScott
Hi Carmen,
You're not missing anything obvious...  This acted a little quirky when I made the change.  I guess it wasn't just me.  The change to the page title didn't seem to want to take for me either, as I thought it should.  I found this worked.....  Comment everything out except your Page.Title = "Address Search" line and recompile.  Test it out to see if the IE tab changed like you would expect.  Then go back uncomment your code and recompile again.  I know its weird, but I stumbled upon this and it did the trick.
Leon
CarmenDurham
Leon,
That's funny because, yesterday, I did try part of what you said (commenting out everything and seeing if I just got a blank page with the real name I wanted) and it did work.  I'll try actually recompiling in VS and placing it back on the server and seeing if that works.
I guess there is some comfort (??) in knowing the quirks are not just me.
Carmen
ZhujingXia
I am new to this thread. I used alive PDF in flex API 1.3. Now I need to upgrade to flex api 2.4. Do you know this alive PDF would work with flex api 2.4 or not?
Zhujing
[email protected]
