Aggregating layers
673
11-30-2012 11:35 AM
DmitriyKukharev
In my application I need to wrap all layers before adding them to the map. For this purpose I implemented proxy class: MyLayer which has similar structure:
class MyLayer extends Layer implement MyInterface
public function MyLayer(originalLayer:Layer)
    this.originalLayer = originalLayer;
///overriden methods from Layer.
override public function createChildren():void
    addChild(originalLayer);
override public function get loaded():Boolean
    return originalLayer.loaded;
/// and others
After I started testing my solution I found that for instance TiledLayer does not work because it expects the parent property to be LayerContainer (otherwise scrcollRect is null and loadTiles() throws runtime error). So I overrode scrollRect property:
override public function get scrollRect():Rectangle
    return parent.scrollRect;
Now everything works well but anyway I am not sure that in future I will not get any problems.
The reason I did this is that I need all layers added to the map implement some interface (MyInterface) that is why I decided to wrap them into my own layer.
Could you recommend something for this case or just tell what other properties (like 'scrollRect') I am required to override.
Thanks.
