Adding MapService (navteq data)
998
06-13-2011 04:57 AM
Abdul_MannanMohammed
I am trying to access a Navteq web service that uses Quadkey & x/y/z interface via a tiledMapService using ArcGIS Flex API in FlexViewer.
The following link displays the tiles from navteq server.How can I add such service into map?
http://1.tl.prd.lbsp.navteq.com/traffic/6.0/tiles/12/2678/1751/256/png?token=XXX&textinfo=false
(just to display the link not as weblink)
there is a token to supplied that i removed from it. may not work with you.
any suggestions!
I am left without a clue...please suggest
BjornSvensson
Esri Alum
If it's not a supported layer, you would have to create your own layer to support this type.  The "Access Custom Tiles" API sample might be helpful.
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=ExtendTiledLayer_CustomTiles
Thanks bJorn for the prompt answer,
I find the sample helpful but still trying to implement the methodology..its little tricky!
once done will post the results. Thanks again
Regards
Abdul mannan
Thanks Bjorn,
I solve the issue that custom layer was so helpful.
Regards
Abdul Mannan
