iOS packaging ipa-debug fails
2807
05-31-2011 11:00 PM
BerndSchneiders
I'm trying to build an iOS ArcGIS Flex application with Flex 4.5.0. Simple apps could be build easily by following this tutorial:
http://va.lent.in/blog/2011/03/25/air2-6-app-for-ios/
I could also build an app with the agslib 2.3.1 which is displaying maps as expected. But this does only work in the Flash Builder "Preview" on my desktop.
When I try to run it on my iPhone, the app is freezing. So I tried to package the app with the ipa-debug target, but the build always fail when I include the agslib. During the build a window is popping up:
Title: Microsoft Visual C++ Runtime Library
Content: Runtime Error! Program: C:\WINDOWS\system32\java.exe
Does anyone managed to run an iOS app including the agslib on Windows?
Best Regards,
Bernd
BerndSchneiders
the problem was related to the AIR 2.6 SDK. With the new AIR 2.7 SDK it is working fine. I can now package iOS apps using the agslib 2.3.1 and run them on the iPhone.
JamesFinnigan
Are you overlaying the AIR 2.7SDK into 4.5.1?  Per the pre-release site, drop3 already has the 2.7 packager but not the 2.7SDK which they are not supporting at the moment.
When I run my iOS app it hangs as described in this thread.  Are you stating that you are seeing a functioning map when using the overlayed 2.7SDK?
