add remove KMLlayer with ArcGIS API 3 for flex (Flash builder 4.6)
3693
6
09-17-2012 07:51 AM
SaidAkif
Hi
I want to add a kml layer (id=xxx) on my map by selecting a checkbox like following:
        <esri:Map id="map">
      <esri:KMLLayer id="chargkml"/>
        </esri:Map>
       <s:CheckBox id="RSS"     click="RSS_clickHandler()"/>
      protected function RSS_clickHandler():void {
                if (RSS.selected) {
                 chargkml.url = "http://www.mapottawa.ca/data/2009_splash_pads.points.kmz";}
                else {
                xxxxxxxxxxxxxxx
It's ok to add because i just set the url of the kml.
my problem is that i don't know how to remove (clear or delete) my kml when I deseleck the checkbos.
Thanks for your help
DasaPaddock
You could bind the visible property to the checkbox like this:
<s:CheckBox id="RSS" label="KML Features"/>
                       url="http://www.mapottawa.ca/data/2009_splash_pads.points.kmz"
                       visible="{RSS.selected}"/>
SaidAkif
Thanks a lot for your answer
It's exactly what I need
sorry, but I have two more questions:
1- With the 'visible', the kml is still charged, How can I delete it?
2- How can I get the kml extend, and zoom the map on it?
IvanBespalov
Try this:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      xmlns:esri="http://www.esri.com/2008/ags">
 <!-- Adobe SDK 4.6 -->
 <!-- ArcGIS API 3.0 -->
 <s:layout>
  <s:HorizontalLayout gap="10"
       paddingLeft="20"
       paddingTop="20"
       paddingBottom="20"
       paddingRight="20"/>
 </s:layout>
 <fx:Script>
  <![CDATA[
   import com.esri.ags.events.LayerEvent;
   import com.esri.ags.geometry.Extent;
   import com.esri.ags.layers.KMLLayer;
   import com.esri.ags.layers.Layer;
   import com.esri.ags.utils.JSONUtil;
   import mx.collections.ArrayCollection;
   import mx.rpc.events.ResultEvent;
   import mx.rpc.http.HTTPService;
   protected function onCheckBoxChange(event:Event):void
    trace(">>>\nBox state chnaged");
    var box:CheckBox = CheckBox(event.target);
    var url:String = box.name;
    if (box.selected)
                                        // create new kml layer here
     var kmlLayer:KMLLayer = new KMLLayer(url);
     kmlLayer.addEventListener(LayerEvent.LOAD, onLayerLoad);
     map.addLayer(kmlLayer); // add to map
    else
     var layers:ArrayCollection = ArrayCollection(map.layers);
                                        // find and remove unchecked layer in map layers collection
     for each (var layer:Layer in layers)
      if (layer is KMLLayer && KMLLayer(layer).url == url)
       map.removeLayer(layer);
       break;
    trace(">>>\nMap layers count = " + map.layerIds.length);
   protected function onLayerLoad(event:LayerEvent):void
    trace(">>>\nLayer loaded");
    var layer:KMLLayer = event.target as KMLLayer;
    layer.removeEventListener(LayerEvent.LOAD, onLayerLoad);
    // get kml layer details
    var httpService:HTTPService = new HTTPService();
    httpService.url = layer.serviceURL + "?url=" + layer.url;
    httpService.method = URLRequestMethod.POST;
    httpService.showBusyCursor = true;
    httpService.resultFormat = "text";
    httpService.concurrency = "last";
    httpService.addEventListener(ResultEvent.RESULT, httpServiceResultFunction);
                                //TODO add fault listener here if needed
    httpService.send();
   protected function httpServiceResultFunction(event:ResultEvent):void
    if (event.result)
     try
      var resultObj:Object = JSONUtil.decode(event.result.toString());
                                                // get layer extent and zoom to it
      if (resultObj.hasOwnProperty("lookAtExtent"))
       var lookAtExtent:Object = resultObj.lookAtExtent;
       map.initialExtent = Extent.fromJSON(lookAtExtent);
       map.zoomToInitialExtent();
     catch (error:Error)
      trace(">>>\nError parsing result");
 </fx:Script>
 <s:VGroup height="100%"
     width="200">
  <s:CheckBox label="2009 splash pads"
     name="http://www.mapottawa.ca/data/2009_splash_pads.points.kmz"
     selected="false"
     change="onCheckBoxChange(event)"/>
  <s:CheckBox label="2010 museums"
     name="http://www.mapottawa.ca/data/2010_museums.points.kmz"
     selected="false"
 </s:VGroup>
 <esri:Map id="map">
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/>
 </esri:Map>
</s:Application>
SaidAkif
realy thanks a lot
rizalosman
Hi akifsaid... Im new in flex and doesn't know about coding. can you this add remove kml widget. I used Arcgis viewer v3.
rizalosman
Hi akifsaid... Im new in flex and doesn't know about coding. can you share this add remove kml widget. I used Arcgis viewer v3.
