Activate drawTool and start drawing with only one mousedown event
2708
06-06-2013 04:51 AM
ab1
Hello,
I'm trying to draw a rectangle on the map using the DrawTool component. I want to start drawing directly after performing a Ctrl + MouseDown.
So in the map_mouseDownHandler function I put the following code:
if(event.ctrlKey){
    // Activate the drawTool
    _context.drawTool.activate(DrawTool.EXTENT);
    // This one seems to be necessary in order to deactivate map pan
    _context.mapRef.dispatchEvent(new MouseEvent(MouseEvent.MOUSE_UP));
But this dosn't work correctly a 100%. After the loading of the map, and only after the loading, It's necessary to perform a Ctrl + MouseDown and then perform a second MouseDown to be able to draw. After this, a Ctrl + MouseDown suffises to start drawing.
Do you have any idea about where the problem could be?
Regards.
ab1
Anyone who's tryed to create a selection by rectangle?
JordanChapman
I saw this when looking through the examples
http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Select_Graphics_within_Extent/01nq0...
ab1
Thank you for the answer 🙂
In my code I do as in the sample. I add drawTool.activate(DrawTool.EXTENT) in the "Mouse Down" event handler.
But the first time that I perform a mouse down on the map (after the map is loaded), the drawTool doesn't work. It works only after that first time.
Furthermore, I have to dispatch a Mouse Up event in order to prevent the pan from happening.
